original header restoration - Pontiac GTO Forum
post #1 of 16 (permalink) Old 09-24-2013, 09:01 PM Thread Starter
67 GTO's Avatar
Hey guys! so previous owner took off the original headers and put on some lousy none original aftermarket headers that have been welded multiple times. When I bought the car they gave me the original ones. however they are in bad shape . The bolts are frozen in their and their all surface rusted. Does anyone know someone or somewhere I can send them to, to get restored and useable again? Thank you
67 GTO is offline
post #2 of 16 (permalink) Old 09-25-2013, 10:58 AM
GTO's did not come with headers. Just exhaust manifolds or RAM AIR manifolds. Headers are aftermarket.
post #3 of 16 (permalink) Old 09-25-2013, 11:11 AM
The casting numbers for GTO exhaust manifolds in 67 are 9779032 (LEFT) and 9779328 (RIGHT).
The casting number for Ram Air and 360hp exhaust manifolds in 67 are 9777646 (LEFT) and 9777641 (RIGHT).
05GTO is offline
post #4 of 16 (permalink) Old 09-25-2013, 11:49 AM Thread Starter
67 GTO's Avatar
sorry guys that's what I meant exhaust manifolds. I was thinking of headers because that's whats on their now but I have the originals im looking to get redone. There in pretty bad shape.
67 GTO is offline
post #5 of 16 (permalink) Old 09-25-2013, 12:11 PM
Quoted: 117 Post(s)
I bead blasted mine and painted them with stove paint. They still look new 4 years and 5000 miles later. But they weren't pitted...just surface rust.
post #6 of 16 (permalink) Old 09-25-2013, 04:50 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I agree with GeeTee about the bead blasting, but I have found a product that I believe works even better than stove paint. It's called Calyx Manifold Dressing. That stuff works fantastic! Your manifolds will look like new and last indefinitely. The additional benefit is that it works on all your cast iron pieces.
chuckha62 is offline
post #7 of 16 (permalink) Old 09-25-2013, 07:59 PM Thread Starter
67 GTO's Avatar
Thanks guys info is helpful. any ideas on some stuck bolts or lugs that are on them?
67 GTO is offline
post #8 of 16 (permalink) Old 09-25-2013, 08:47 PM
Heat, you need a torch, heat them up 1 @ a time till the ears are red hot (trying not to heat the stud), then use a stud removal tool to get them out. Use a tap to clean up the threads before installing new studs.
post #9 of 16 (permalink) Old 09-26-2013, 01:26 PM Thread Starter
67 GTO's Avatar
thanks Ruke! im gunna try that than hopefully be able clean them up
67 GTO is offline
post #10 of 16 (permalink) Old 09-27-2013, 11:30 PM
leeklm's Avatar
Run them through an electrolysis process. I have instructions in a restoration book, or simply Google the process. I have never tried it, but looks like a pretty slick process on old rusty iron. All you need is a battery charger and a tub of water.
leeklm is offline
Is transmission original?? doc21127 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 08-21-2013 08:45 AM
Non-Original Color Vito321 1964-1974 Tempest, Lemans & GTO General Discussion 2 08-06-2013 09:41 PM
where's my original motor masterblaster 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 08-08-2012 10:12 PM
Original Color or Something Else Chips 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 11-27-2011 02:50 PM
