Outer wheelhouse replacement - 70 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-02-2015, 11:44 AM Thread Starter
Orion88's Avatar
I have hit a snag on my restoration and I can't move forward until I figure it out. I already replaced my drivers side quarter panel no problem. Now I am working on the passenger side. But when I removed the old quarter, part of the wheelhouse came with it. I have my new wheelhouse now but I am not sure how to go about removing the old one. It is attached to some structural parts so I don't wanna just go cutting out whatever I feel like, and a friend of mine who does restorations says not to drill out the spot welds and remove the whole wheelhouse like you would the quarter. So what do I do? Has anyone done this swap before, or know of an online resource that shows how to do it?
"You Gotta Have Fun When You're Little!!"
-Dick Schindler
Orion88 is offline
post #2 of 4 (permalink) Old 02-02-2015, 09:10 PM
I replaced both sides inner and outer on my 66, click on the My Photos link under my avatar, I believe we drilled the spot welds.
05GTO is offline
post #3 of 4 (permalink) Old 02-03-2015, 01:13 PM
Red1970GTO's Avatar
You can drill out the spot welds where the two sections (Inner House and Outer House) meet, HOWEVER, at the point where the Outer House attaches to the C Pillar you need to leave the factory welds and cut the Outer House sheetmetal. You want to leave just a relatively small section of the original Outer House as a "lip." that way you can weld (or glue!) the new Outer House to that "lip" section. You can "joggle lap" the joint to get a better fit. Here's a photo of the completed task: In The Shop Photo by NickeyChevelle | Photobucket
Red1970GTO is offline
post #4 of 4 (permalink) Old 02-03-2015, 01:20 PM Thread Starter
Orion88's Avatar
So you leave a piece under the C pillar, do you cut that piece out of the new wheelhouse and weld it to the old piece? And on the front half, the outer wheelhouse lip is on the inside of the car. Where do you drill that out? And where it goes into the rocker panel?
-Dick Schindler
Orion88 is offline
65 GTO frame off restoration, wheelhouse question bw5500 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 08-31-2013 08:04 PM
69 GTO Outer Wheel House Fit Issues FooGee 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 12-20-2012 04:47 PM
'67 GTO Inner and Outer Rocker Replacement LewisT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-30-2010 06:03 PM
68 GTO Convertible Outer wheel house rear. mohrfeld16 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-18-2010 07:34 PM
