Package Shelf - Pontiac GTO Forum
 1Likes
post #1 of 11 (permalink) Old 02-06-2019, 05:53 PM Thread Starter
Hiandfast's Avatar
Quoted: 4 Post(s)
Package Shelf
Hi Y’all
Finally getting to my project. The package shelf is pretty much toast. Any ideas on where to buy a new one or a good cut out from a junk yard?
Perry
Hiandfast is offline
post #2 of 11 (permalink) Old 02-06-2019, 07:36 PM
Quoted: 8 Post(s)
I believe a company called REM makes them. The new ones aren't very costly but the shipping may get you.
1966GT0 is offline
post #3 of 11 (permalink) Old 02-07-2019, 08:40 AM
If you're not that worried about 100% original, you can make one pretty easily. That's what I did on my '69. I used the old one as a template, cut a new one out of a thin piece of masonite, added oval cutouts for the rear sound system speakers I'm using, then covered the whole thing in a relatively fine mesh black speaker grille cloth. It looks very good.
1968gto421 likes this.
post #4 of 11 (permalink) Old 02-11-2019, 10:45 AM Thread Starter
Hiandfast's Avatar
Quoted: 4 Post(s)
Thanks for the replies. I need to be more specific. What I need is the metal that creates the package shelf along with the bracing down to the floorpan. The big Sheetmetal Sellers don’t have a replacement. I was also wondering if the metal package shelf from a 1967 Chevelle would work?
post #5 of 11 (permalink) Old 02-11-2019, 06:20 PM
Quoted: 347 Post(s)
Originally Posted by Hiandfast View Post
Thanks for the replies. I need to be more specific. What I need is the metal that creates the package shelf along with the bracing down to the floorpan. The big Sheetmetal Sellers donít have a replacement. I was also wondering if the metal package shelf from a 1967 Chevelle would work?
You may find it here: https://www.frankspontiacparts.com/
post #6 of 11 (permalink) Old 02-12-2019, 08:17 PM
Quoted: 31 Post(s)
Had this issue with a 69 gto a few years ago. If nothing has changed which I don't think it has you will not find a direct replacement . Just not made for gto . Why I don't know. But I can tell you the Chevelle is snd is very close and are sold . Best luck . Finding a used good one is like finding a neddle in a hay stack Doug
dd68gto is offline
post #7 of 11 (permalink) Old 02-12-2019, 08:22 PM
Quoted: 31 Post(s)
Sorry thought this would be a good start for you. Like I said not the same but it gives you a good start . https://www.summitracing.com/parts/amd-640-3468/
dd68gto is offline
post #8 of 11 (permalink) Old 02-13-2019, 09:32 AM Thread Starter
Hiandfast's Avatar
Quoted: 4 Post(s)
Thanks for all the replies. I have talked to all the junkyards that sell Pontiac parts. So far no luck. I might try Doug’s idea and modify the 67 Chevelle package tray. I’m still open to any and all ideas out there. Thanks again, Perry
post #9 of 11 (permalink) Old 02-13-2019, 03:36 PM
Quoted: 31 Post(s)
I search every where when we did the 69. They are just not out there or you will find it's as bad as yours or worse . Once in you can't see it except getting in trunk and looking at it . Unless your doing a # 1 Concourse car the Chevelle is the fix and many have used . Good luck Doug
dd68gto is offline
post #10 of 11 (permalink) Old 02-13-2019, 06:48 PM
Quoted: 4 Post(s)
Try auto metal direct, i found one for my 69 gto there. Almost a perfect fit and very similar.
Real69gtojudge! is offline
Lingenfelter Magnacharger Package Vs GEN TT Twin Turbo Package BMWkilla17 2004-2006 GTO General Discussion 21 08-22-2007 04:12 PM
Red Pulse Appearance Package toyotatom 2004-2006 GTO General Discussion 3 01-16-2006 06:53 AM
Fabric on parcel shelf bubbling GM Kid 2004-2006 GTO General Discussion 5 08-22-2005 08:33 PM
Buzzing Rattle in Back Shelf from Bass Groucho 2004-2006 GTO General Discussion 3 09-18-2004 07:07 PM
