PCV connections - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-22-2011, 07:02 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
PCV connections
As I understand it, PCV valve in front of valley pan,connects via a 3 way "V" shaped connector to the 2 PCV ports on the front top of the intake manifold.
As in the 1st pic.
And the same as the 2nd pic.........
Yet why do I have this 2 foot long hose that I see on so many cars?
Is there a 4th connection for the PCV?
Could my old (missing valley pan have had the PCV valve in the rear of pan?
R confused.
what gives?
thanks as always
ID:	10403   Click image for larger version
ID:	10404   Click image for larger version
Topkat is offline
post #2 of 3 (permalink) Old 02-22-2011, 08:26 PM
Quoted: 118 Post(s)
Your valley pan is supposed to have the PCV valve plugged in at the passenger side rear. Do you have the "wrong" valley pan?? The PCV hose on the '67 goes from the rear of the pan, thru the bracket, tees off, and then both ends plug into the intake ports.
post #3 of 3 (permalink) Old 02-23-2011, 06:28 AM Thread Starter
Topkat's Avatar
it fits perfectly and at over $100's i'll get used to it lol
Topkat is offline
smog pump connections on 67 Goat Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-15-2011 09:16 PM
Pcv Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 02-01-2011 07:28 AM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
Need Some Help With PCV 2kThunder Service, Maintenance and Technical Discussion 4 11-10-2006 12:29 AM
