Please explain the degrees of gloss like 30 or 60 - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-08-2011, 05:25 PM Thread Starter
I see different black paints called out for different parts. I get that the part about flat black or full gloss. I would like to know how to do a 60 degree gloss.
I would really like to have a fender with the different glosses painted on it with corresponding gloss degree.
Thanks for you input.
67blackgoat is offline
post #2 of 5 (permalink) Old 12-08-2011, 06:40 PM
Quoted: 102 Post(s)
Semi gloss, like in the rattle cans, is about a 60% "gloss". Semi-flat, again in the rattle cans, is about a 20% gloss. "Gloss" is 100% gloss, and "Flat" is 0% gloss....At least that's what I've run into.....
post #3 of 5 (permalink) Old 12-08-2011, 07:23 PM
6 parts gloss mixed with 4 parts flat, also, mix with an oil based thinner and spray. Holds up nicely, same shine as the eastwood products.
ID:	13193   Click image for larger version
Name:	black gloss.jpg
ID:	13194   Click image for larger version
Name:	black thinner.jpg
05GTO is online now
post #4 of 5 (permalink) Old 12-08-2011, 11:05 PM
Quoted: 23 Post(s)
with both ^^^ although i did do my inner fenders in epoxy just because they may get exposed to brake and power steering fluid and i had a can of black industrial on hand and used a flattening powder to get the right sheen.
40% gloss in rattle cans (satin)
we did a whole 16' work trailer in Rustoleum for under 100.00 paint is paint on the working parts (Underside, wheel wells of the car)
Instg8ter is offline
post #5 of 5 (permalink) Old 12-09-2011, 09:07 AM
Quoted: 102 Post(s)
Rustoleum is good stuff. It takes a while to dry, but it's tough and holds up. I did the underpinnings of my '15 ford with it 6 years ago, as well as some of the upper parts, and it still looks like new. Plus, it's a cinch to match if you get a chip...
Gloss, Satin, or Flat on Fender Wells, etc??? 70455goat 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 11 07-30-2013 09:59 PM
Converting foot pounds + 140 degrees danfigg Service, Maintenance and Technical Discussion 14 08-08-2010 09:45 PM
Please explain the 1st to 4th indicator on a manual 06 GuatoLT1 Drive train, suspension, alignment and brakes. 6 09-04-2009 04:12 PM
Just Curious, Please Explain RED68GTO 2004-2006 GTO General Discussion 13 11-27-2004 10:55 AM
