Project: 1967 GTO Mechanical Restoration - Pontiac GTO Forum
post #1 of 18 (permalink) Old 06-22-2007, 11:16 AM Thread Starter
I want to begin by introducing myself. My name is Keith and I work for a restoration shop in Cookeville, TN called Mid-Southern Restorations. www.midsr.com We are now in the process of doing a mechanical restoration of a 1967 GTO with 400. Our customer has decided to have a good fondation before having the car repainted. We will be replacing the driver's floor and the trunk floor. There was lots of patch work performed prior, and it needs to be done in a better fashion. We will pull the drivetrain and have it inspected and rebuilt when nessesary. The car actually runs pretty strong. I feel that others would like to see the project as it unfolds and is completed. I am in no way a perfessional know it all of GTOs, and ask they everyone understands that this is not going to be a chalk mark restoration, but a freshing up. I will be posting pictures at every post, and ask that all comments be put onto another thread as this will make the project more enjoyable to read. PLEASE DO NOT POST ON THIS THREAD!!!!
Name:	67 gto 059 (Small).jpg
ID:	1459   Click image for larger version
Name:	67 gto 063 (Small).jpg
ID:	1460   Click image for larger version
Name:	67 gto 067 (Small).jpg
ID:	1461   Click image for larger version
Name:	67 gto 071 (Small).jpg
ID:	1462   Click image for larger version
Name:	67 gto 072 (Small).jpg
opelspyder is offline
post #2 of 18 (permalink) Old 06-22-2007, 11:23 AM Thread Starter
Bumpers to be rechromed
The custmer requested we have the bumpers rechromed, so I removed them for shipping. We try to find places that will triple plate the bumpers as it seems to be the standard now.
Keith
Name:	Begin trunk 005 (Small).jpg
ID:	1464   Click image for larger version
Name:	Begin trunk 004 (Small).jpg
post #3 of 18 (permalink) Old 06-22-2007, 11:29 AM Thread Starter
Begin trunk floor-new metal
Ordered new trunk floor(3 piece with body mounts) and drivers floor from Ames. Look to be a pretty good selection of replacement metal. Looks like it will take a while to remove the original trunk floor and retain some of the rear outer panel areas from underneath. I began by chiseling out the seam sealer, as this will let me see how the seams are made on the trunk. The trunk appears to have been cut out, and then put right back in-very nasty looking seems. They used some kind of plumbers putty. Anyways here are some pics
Keith
Name:	Begin trunk 006 (Small).jpg
ID:	1466   Click image for larger version
Name:	Begin trunk 007 (Small).jpg
ID:	1467   Click image for larger version
Name:	Begin trunk 008 (Small).jpg
post #4 of 18 (permalink) Old 06-22-2007, 11:34 AM Thread Starter
Gas tank removal and floor cut out
Here I pull out the gas tank, which ended up being quite easy. I like the way the sending unit can be removed with the gas tank in, or at least the wires ran to it. I begin with a plasma cutter and cut along where the panels will be close to meeting up to, then I can get better access to the final metal removal process.
Keith
Name:	Gas tank and floor 001 (Small).jpg
ID:	1469   Click image for larger version
Name:	Gas tank and floor 002 (Small).jpg
ID:	1470   Click image for larger version
Name:	Gas tank and floor 003 (Small).jpg
ID:	1471   Click image for larger version
Name:	Gas tank and floor 004 (Small).jpg
post #5 of 18 (permalink) Old 07-10-2007, 09:12 AM Thread Starter
Trunk floor making progress
I've been tied up working on a Packard to even be able to touch the GTO until yesterday. I was able to spot in the main trunk floor and then today I am working on the underneath areas, like gas tank mounts and body mounts. Our original trunk wasn't bad, but the PO (previous owners) obviously cut it out, and then rewelded it (the same floor) back in. Well not really rewelded it as it was obvious they did not have a welder. They used kittyhair and mesh screen to bond it. I should have more updates more often for you. We are talking with the customer about doing other things as well.
Keith
Name:	Trunk Floor 002 (Small).jpg
ID:	1549   Click image for larger version
Name:	Trunk Floor 003 (Small).jpg
ID:	1550   Click image for larger version
Name:	Trunk Floor 001 (Small).jpg
post #6 of 18 (permalink) Old 07-17-2007, 04:19 PM Thread Starter
Floor primed
The trunk floor has now been primed and seam sealed on the underside. The multiple piece trunk is a tough one to get everything right on. They are not perfect stampings, although I have not seen one yet unless it was NOS. Anyways I used a self etching primer here for bare metal use. The customer decided to not undergo a frame off at this time due to budjet, so we are forced to work around these areas. Its not 100% this way, but it is taking care of the metal at least. Hopefully for the paint job years from now these areas will be detailed out and brought up to where the mechanical will be. Have to start somewhere. Next I will begin engine removal, and work into doing the driver's floor. The pictures show underneath the trunk, but being black, will not be of high detail. Hard to get proper lighting on these shots.
Keith
Name:	Trunk primed 001 (Small).jpg
ID:	1565   Click image for larger version
Name:	Trunk primed 002 (Small).jpg
post #7 of 18 (permalink) Old 07-18-2007, 04:21 PM Thread Starter
Gas tank
We are installing a new gas tank. Doesn't seem like new senders are available, but fortunately ours was in excellent shape, and after a quick ohm test, its in the new tank. I installed the tank and will run new fuel hoses to it as well.
Keith
Name:	Gas tank 001 (Small).jpg
ID:	1567   Click image for larger version
Name:	Gas tank 003 (Small).jpg
post #8 of 18 (permalink) Old 07-18-2007, 04:27 PM Thread Starter
Engine being removed for rebuild
Engine is getting ready to be removed for complete rebuild. It appears to have had prior work done...but to what extent we do not know. It runs strong, but does smoke on the one bank. So we know some head work will be required. Here are the pics
Keith
Name:	67 gto 012 (Small).jpg
ID:	1569   Click image for larger version
Name:	Gas tank 002 (Small).jpg
post #9 of 18 (permalink) Old 07-23-2007, 02:18 PM Thread Starter
Driver's floor section replacement
While the engine is being rebuilt-(found head was cracked), I have time to do the driver's floor section that has some rust. It appears that water or moisture built up around the wiring channel and caused the rust. It was patched with tile putty or something of that nature. I Pulled back the interior to do this, All these procedures would be easier if the frame was removed, unfortunetly we have to work around that. I will finish coating the trunk and floor, and we will then be working on the engine bay and rear end. It will visit a steam cleaner first.
Keith
Name:	Driver's Floor 001 (Small).jpg
ID:	1579   Click image for larger version
Name:	Driver's Floor 002 (Small).jpg
post #10 of 18 (permalink) Old 07-24-2007, 11:48 AM Thread Starter
Steam cleaning
I finished the floor section and it turned out pretty good. We find that steam cleaning the undercarriage and suspension areas really make it easier to work on these cars. I strip the paint and all on the front crossmember, and the backing plates of the brakes are blasted as well. These were covered with thick hardened grease as well and you can see how clean they got. I did underneath as well due to we are now going to wire buff underneath and undercoat this car. Also more news on the engine, the block was cracked. Fortunetly we had a block to use for it, so everything on the rebuild will continue to go smooth. Hopefully there will be no more surprises on that. The car will be moved back to the lift so further dissassembly can take place. The front suspension will be redone with new bushings from PST. Also the rear end will be removed for bushings, springs, and rebuild.
Keith
Name:	Steam cleaned 001 (Small).jpg
ID:	1587   Click image for larger version
Name:	Steam cleaned 002 (Small).jpg
ID:	1588   Click image for larger version
Name:	Steam cleaned 003 (Small).jpg
ID:	1589   Click image for larger version
Name:	Steam cleaned 004 (Small).jpg
