Put an order in for replacement panels - Pontiac GTO Forum
post #1 of 17 (permalink) Old 03-27-2009, 01:32 PM Thread Starter
67 Basket Case Restorer
Too Many Projects's Avatar
Well, I'm committed now. I placed an order with a local GoodMark dealer for the 1 piece floor, both inner and outer rocker panels, seat mounts and the left toe panel. That will get the car back in shape to the trunk. I'm still on the fence with a roto so I didn't go ahead with the full trunk floor and tail panel at this time. The dealer MAY have a lead on a roto to borrow/rent and if that comes thru, I will add more parts to the order. An added bonus is he has enough other parts to order for free shipping....
I can't believe I'm doing this...... I'll either be the envy of all my car buddies or the new town fool if it blows up.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #2 of 17 (permalink) Old 03-27-2009, 02:48 PM
I'll rent or sell my roto, are you up for a road trip to North GA.
05GTO is offline
post #3 of 17 (permalink) Old 03-27-2009, 03:48 PM Thread Starter
If it's the one in your resto pics with the lifting jacks and balancing screws, I'm interested in a purchase price. Don't think I'd want to make the trip twice for a rental return.....
Mitch
1962 Impala SS
1938 Chev coupe
post #4 of 17 (permalink) Old 03-27-2009, 08:23 PM
Quoted: 117 Post(s)
Anybody even ATTEMPTING a restoration of the magnitude your dealing with is a HERO in my book. Even if you totally screw it up, it's still gonna be better than before, and at least you GAVE IT A TRY. Get R done!
post #5 of 17 (permalink) Old 03-28-2009, 09:50 AM Thread Starter
THANKS Jeff........it's amazing how my mind set went from "I want a solid body car to drive" to "I'm gonna rebuild this sucker"..... Kind of like the bionic man. We have the tools and technology to build it better, faster, stronger.
Mitch
1962 Impala SS
1938 Chev coupe
post #6 of 17 (permalink) Old 03-30-2009, 08:00 PM Thread Starter
Randy, are you thinking about this ?
Mitch
1962 Impala SS
1938 Chev coupe
post #7 of 17 (permalink) Old 03-30-2009, 08:28 PM
PM sent,
05GTO is offline
post #8 of 17 (permalink) Old 03-31-2009, 09:22 PM
injn37's Avatar
Mitch,
If your trunk floor was as trashed as mine ( no mounts worth attempting to hang the body from), I took and drilled two holes in the tail panel ( on the underside) and using two spacers between the rotiserrie arms and the underside of the body ( there is a lip there that you need to clear), you can hang the body from there. That way , you have a clear span to replace the trunk floor, gas tank braces and frame mounts. It also allowed me to install the tail piece unobstructed. If you have to repace the tail piece, make sure you weld in the cage nuts ( not supplied) before you make sparks. Otherwise you will be pissed at yourself. ( No, I didn't forget, right after I started fitting,but before welding!).
SHout, if you need to check , as I just finished that surgery, and the pain is still fresh in my mind.
rich
injn37 is offline
post #9 of 17 (permalink) Old 03-31-2009, 10:19 PM Thread Starter
Hey Rich, actually the last brace and mounts are good.....everything in front is gone/trash. I do need to replace the floor and tail panel but that won't be for a while. I am going to use the 1 piece trunk floor and the last brace and cage nuts are SUPPOSED to be attached already. It's plenty strong enough to hang the body with for now and I am just shooting for the cabin floor and all rockers for now.
Got a roto on the local Craigslist but he wants a bit much for it as a plain jane. I asked for better pics and a manufacturer today. He is supposed to get back with that in a day or two.
Wish I had the time and coin to go get Randy's deluxe model and go to a couple salvage yards down there. It would be a fun trip and probably rewarding for parts too, but alas, time and funds are running out quickly.
Mitch
1962 Impala SS
1938 Chev coupe
post #10 of 17 (permalink) Old 04-01-2009, 06:45 PM
injn37's Avatar
Funny when you have the money, you don't have the time and when you have the time, you don't have two pennies to rub together!
Hope you score a rotisserie, as it will really help make it easy. One of my friends who is putting together a 32 Pontiac streetrod, right next to mine, purchased a spot welder from Northern. Other than giving you a hernia, I used it to put the inner and outer rockers together, and it was sweet! Just wish it would reach all the floor braces!
Your lucky if you still have some mounting points to reference off of. It makes a big difference.
Later,
rich
injn37 is offline
90/10 Struts Available for Pre Order [email protected] Drive train, suspension, alignment and brakes. 0 10-16-2008 08:03 PM
GMM Shifter--Did you you put the "fluffball" back in? Gooooat Drive train, suspension, alignment and brakes. 9 04-25-2006 02:39 AM
My order timeline jerrybramlett 2004-2006 GTO General Discussion 2 06-28-2005 06:47 PM
