Putting the shine back on metal - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-23-2012, 05:42 PM Thread Starter
jigaway's Avatar
Maybe should have put this in the DIY restoration thread.
While it's downtime in the Winter, I wanted to shine up some of the metal under the hood, namely my Wiper motor and pump. But I'll ask for any metal.
Any secrets or advice for making metal shine again? Other than the obvious take a wire brush to it, is there a chemical, or abrasive that pretties up oxidized, old metal??
thanks in advance,
Dan
jigaway is offline
post #2 of 2 (permalink) Old 02-23-2012, 07:16 PM
Quoted: 23 Post(s)
Start with simple green to get all dirt and grime off, painted parts can be glossed over with satin black from a rattle can. Metal parts with light oxidation can be hit with aluminum wheel cleaner, heavier you can use Naval Jelly, 0000 steel wool and then a felt padded dremel with rubbing compound will polish it back up. More than one way to skin a cat, cleaned up hinges and Brake booster and sprayed them with rustoleum platinum silver epoxy....
Instg8ter is offline
Help needed with putting a '67 GTO carb back to stock 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-25-2011 07:20 PM
'66 GTO getting close to putting on new coat 2drhdtp 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 12-18-2010 06:44 PM
Shifter problems after putting the tranny back in trutech74 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-22-2009 08:00 PM
putting cats back on?? jrey408 Intake and Exhaust Discussions 2 06-23-2009 09:15 AM
putting a bbc or sbc in my 67 gto hottrodd57 Engine Discussions 1 11-13-2006 08:48 PM
