Question on '65 fender clips (inner and outer) - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-06-2011, 09:06 AM Thread Starter
I am just starting to put things back together, and having trouble figuring out the right connectors to use to mate the front inner fender to the outer fender. I purchased what I thought was a complete kit of connectors for the front, but none of the supplied bolt/clip combinations seem to work. These are the blind fasteners that have a square hole on the inner fender to attach a clip to. The metal spring clips I have are not long enough and I can't seem to find these called out in my restoration guide. Any ideas/pointers would be appreciated.
Fred007 is offline
post #2 of 5 (permalink) Old 08-06-2011, 10:40 AM
FNG69's Avatar
Uploaded with ImageShack.us
Did you start with these two...Les
FNG69 is offline
post #3 of 5 (permalink) Old 08-06-2011, 02:05 PM
Ames performance part numbers C107G for the plastic clip and bolt for mounting the ineer to the outer U clips for the fender to the top of the well are 1 inch long. Same clips for the front of the well to the radiator support. There are two types of fender wells One has nuts welded into the well top and the other has holes which require the U clip and bolt All can be purchased but if you took it apart I would bet you have them.
Steve
twomedicine1 is offline
post #4 of 5 (permalink) Old 08-07-2011, 10:22 AM Thread Starter
Thanks for the help, I think the Ames part is exactly what I am looking for.
Fred007 is offline
post #5 of 5 (permalink) Old 08-07-2011, 01:49 PM
Those u-clip nuts can be bought at NAPA~ part # 665-1461.
Outer Tire Rod Jermaine 2004-2006 GTO General Discussion 3 07-22-2010 07:15 PM
'67 GTO Inner and Outer Rocker Replacement LewisT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-30-2010 06:03 PM
1964 GTO front fender question 1ernhrt 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 9 02-03-2010 07:49 PM
front inner fender paint question blondie67 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 1 08-24-2008 06:51 PM
fender roll question? enjracing 2004-2006 GTO General Discussion 0 07-21-2006 06:52 PM
