Question about repainting grill, emblems 65 GTO - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-18-2011, 02:37 PM Thread Starter
Guys,
I'm trying to get the white paint off the chrome GTO emblem that attaches to the grill. I started to chip it off, but I would rather not scratch the chrome.
Any suggestions what to use to get the paint off? Also, is there a specific white paint to use to repaint it?
Also, I'm going to repaint the grill, would Eastwood be the place to go to get the closest to factory paint for it?
One last question, I just took the hood scoop out (it's not a ram air car).
It's very tempting to buy a ram air scoop from Ames, but making it work would entail cutting the small metal pieces behind the scoop.
I'm planning on keeping the car when it's done, but I wanted to get a consensus from anyone that would want to give me his .02...would it be worth having that piece cut, or should I leave it alone?
Here's the kicker, it's a numbers matching, all original, except for
the carb, now tripower, the vinyl roof, now metal, and was originally a 3 spd, now it's a 4 spd.
Your .02?
Thanks,
Paul
pbertrand65GTO is offline
post #2 of 5 (permalink) Old 12-18-2011, 03:27 PM
blackplate65's Avatar
a corse rubbing compound will take the paint off easy and what no pics ??
blackplate65 is offline
post #3 of 5 (permalink) Old 12-18-2011, 10:36 PM
Roger that's Avatar
Try Klean-strip Aircraft paint remover. As far as the ram air, all 65s did not have them as a factory option. Ram air became a dealer installed option half way through the 65 run. Keep it original.
Roger that is offline
post #4 of 5 (permalink) Old 12-19-2011, 09:11 AM
Quoted: 102 Post(s)
Paint stripper should take the paint off, too. I'd use a nylon brush and go easy. I cut the hood on my all original '67 to install a functional scoop and a ram air setup 25 years ago. You can't tell unless you look. Would I do it again? No. Not on an original car. Does it help? Perhaps. I can't tell. There is no "Ram" effect up there on the hood....it's back at the cowl where Chevy took advantage of it. The Pontiac Ram Air scoop does bring in cool, dense air, which is good for making power.
post #5 of 5 (permalink) Old 12-20-2011, 07:17 PM Thread Starter
Thanks for your honest opinions
Guys,
I appreciate the feedback. I'm going to keep in orig.
I've been using the aircraft stripper for the rest of the body,
I'll keep using that.
And Rogerthat, I'll post pics soon.
Repainting the engine in our 65 SIXT5GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-16-2011 07:37 PM
Repainting between ribs next to tail light lens Gary Brewer 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 02-28-2011 10:16 AM
Repainting 05 GTO speedfeed Exterior Discussions 7 08-24-2010 02:18 PM
Emblems on 66 GTO Richie Cat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-17-2008 11:58 AM
Why or why not the emblems on my car? azmusclecar 1964-1974 Tempest, Lemans & GTO General Discussion 6 10-08-2007 05:57 PM
