Rear Inner Wheel Well contour HELP - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-31-2010, 11:47 AM Thread Starter
MaL
MaL's Avatar
Send a message via AIM to MaL
We're trying to figure out the correct line the rear well should have.
The pictures are of the driver's side facing the rear of the car. I'm pointing to the line that we're unsure of. The original metal has a very straight line that we believe was cut there and isn't original. The replacement metal goes farther out, but we don't know exactly how it should look.
Does anyone have a closeup picture of this area?
Happy New Year!
MaL is offline
post #2 of 8 (permalink) Old 12-31-2010, 12:35 PM
Chipper7's Avatar
What year car are you working on?
Chipper7 is offline
post #3 of 8 (permalink) Old 12-31-2010, 03:07 PM Thread Starter
MaL
MaL's Avatar
1966
MaL is offline
post #4 of 8 (permalink) Old 12-31-2010, 03:09 PM
Quoted: 23 Post(s)
do not know if this helps as mine is heavily undercoated but it is original as far as i can tell
Instg8ter is offline
post #5 of 8 (permalink) Old 12-31-2010, 06:10 PM
Hi,
I've gone through this repair in that area on my 67. I had alot of requests for the template, so I made a template off of my originals and then made it into a pdf file. You can print it out; should print out lifesize on a letter size paper.
Go to my website: Squid's Fab Shop Home
On the left is the navigation menu.....click on the wheelhouse filler pdf file.
You can also go the the "trunk" page and see what they look like being installed (scroll down it's in there).
Let me know if they work out for you.
Good luck!
Dave
Squidtone is offline
post #6 of 8 (permalink) Old 01-01-2011, 10:47 AM Thread Starter
MaL
MaL's Avatar
Thanks, guys. I appreciate the pictures and template.
Squidtone, I know the 66 and 67 qtrs are slightly different, but the template area is good for both years, right?
MaL is offline
post #7 of 8 (permalink) Old 01-01-2011, 04:37 PM
Well I can't say for sure, but if I had to guess, I'd say wheelwell fillers are the same pieces for 66 and 67. Replacement outer wheelhouse numbers are the same for 66-67; I'd say the wheelwell filler is the same too.
dave
post #8 of 8 (permalink) Old 01-02-2011, 10:34 AM
That piece is on my 67 and was on my 66 also.....I USED to know why Pontiac did that but can't remember any more.....E
Eric Animal is offline
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 2 10-15-2018 08:00 AM
Rear Wheel Alignment Vettekid1992 Drive train, suspension, alignment and brakes. 1 06-04-2010 09:21 PM
How much rear wheel HP kanibal Engine Discussions 3 01-05-2007 12:23 AM
Rear Wheel Studs R TITTLE Wheels and tires 2 07-12-2006 07:08 AM
Rear wheel HP StangStalker Service, Maintenance and Technical Discussion 1 08-27-2005 09:47 PM
