Rear lower shock mounting stud - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-02-2017, 07:41 PM Thread Starter
Quoted: 17 Post(s)
On my 69, one of the lower shock mount holes on the differential is in need of repair. What is the correct diameter for these holes?? Thanks
greenjudge69 is offline
post #2 of 5 (permalink) Old 01-02-2017, 10:49 PM
shader's Avatar
Quoted: 9 Post(s)
Since it's only one hole, if possible why not just measure the size of the good one? Actually, the hole only needs to be big enough for the shock mounting stud to fit. Take a drill gauge and measure the OD of the stud and size accordingly.
shader is offline
post #3 of 5 (permalink) Old 01-03-2017, 08:19 AM Thread Starter
Quoted: 17 Post(s)
Because the other hole is worn as well but not as bad as the right one and I have not purchased new shocks yet
post #4 of 5 (permalink) Old 01-03-2017, 11:21 AM
shader's Avatar
Quoted: 9 Post(s)
Both shock holes worn-was this a drag race car? The rear shock stud size is the same for 64-72 and is so thats the hole size needed.
shader is offline
post #5 of 5 (permalink) Old 01-03-2017, 12:07 PM Thread Starter
Quoted: 17 Post(s)
Probably, since it was ordered with some interesting options. I'm actively searching for information about all previous owners but it's not easy. Thanks for your help.
Rear shock mounts in need of repair - How? bkellis1 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-02-2015 10:16 AM
Rear shock removal SSnakeAce 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 02-25-2015 10:41 AM
69 lower control arm mounting torque spec dan woodland 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 08-22-2014 07:25 PM
Issue With Rear Shock Removal Red2005Goat 2004-2006 GTO General Discussion 3 09-08-2013 03:22 PM
rear shock question bobby326 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 02-08-2010 01:13 PM
