Rear seat floor pan install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-27-2016, 02:43 PM Thread Starter
Layzdude's Avatar
Found a bit of a mess under my rear seat when I removed it and the seat belts. The tunnel is good but around the seatbelt bolts is rotted through and parts of the floor. Anything white in the pic is a hole. Figured best to replace the whole panel. Looks like the old panel can be cut out pretty easy. Anyone ever replace this panel. Any help or suggestions would be appreciated. Got a replacement from Dynacorn. My plan is to use the new panel as a template and lap joint weld it. I read that butt welding is the best way but I feel I don't have the skill set for that. Plus I am using flux core wire.
Sorry for the long post
Attached is a pic of the rear and a pic of the replacement panel
ID:	75642   Click image for larger version
Layzdude is offline
post #2 of 3 (permalink) Old 04-27-2016, 02:48 PM Thread Starter
Layzdude's Avatar
Layzdude is offline
post #3 of 3 (permalink) Old 04-27-2016, 02:51 PM Thread Starter
Layzdude's Avatar
Layzdude is offline
Trunk Floor Pan - can I use a 67 chevelle trunk pan in my 67 GTO SOCMedic 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-19-2015 08:30 PM
Floor pan plugs FlambeauHO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 01-22-2012 09:48 PM
floor pan 67chivo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 10-15-2011 03:42 PM
install 04 rear seat in 65 crustysack 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 24 11-16-2009 10:35 PM
floor pan painting Joe 49 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-29-2009 05:05 PM
