reel out trunk light trouble - Pontiac GTO Forum
post #1 of 13 (permalink) Old 09-10-2011, 05:47 PM Thread Starter
well i found a nice reel out trunk light on ebay, bulbs good, cords good, sockets good but were the cord gos in the bracket there some sort of connector, its spring loaded but dont stay in, you push it in and wiggle it and the light will come and go some but when you let go it gos off, is this a combo switch connector or what? since these were made to take out i know they didint have a mercury switch so what kinda switch did they normaly have when you got that option? and i see some have a switch but mine has the connector were the switch is, is it a fuse holder? hows it come apart?
danthepontiacman is offline
post #2 of 13 (permalink) Old 09-10-2011, 05:55 PM Thread Starter
heres the pics
ID:	12202   Click image for larger version
ID:	12203   Click image for larger version
post #3 of 13 (permalink) Old 09-11-2011, 07:38 AM
Dan, That is a Mercury switch. It stays on the mounting bracket. When you open the trunk lid, the switch turns the light on (so the light MUST mount to the lid). You can then reel the light out and it will remain lit. The wire frequently becomes detached. It isn't really servicable. I have seen them removed and replaced with a toggle switch....Eric P.S. Some guys have glued the wire back in with crazy glue ...Personally, I'd go the toggle switch route.
Eric Animal is offline
post #4 of 13 (permalink) Old 09-11-2011, 01:54 PM Thread Starter
ok well im gonna be hooking it up in my tempest, i know it was a dealer option at that time seeing has its in the dealer stuff that came with the car when new o na list f things the dealer could add, soo where is the sam hill would it plug up? or hookup?
post #5 of 13 (permalink) Old 09-11-2011, 02:46 PM
I have a NOS one in my stash....I will see if the install instructions give a "suggested location" ....gimme a few minutes. Eric
post #6 of 13 (permalink) Old 09-11-2011, 02:57 PM
Dan, sorry, no instructions in the box. I have seen them mounted on the trunk lid, to the left of the jack instructions. There is a hole for you to snake a wire through...down to the left, is where it should come out and clip onto the trunk hinge, then tap into the rear light harness near the left wheel well. best I can tell ya' ...E
post #7 of 13 (permalink) Old 09-12-2011, 09:46 AM Thread Starter
thanks for the info, i put a metor on it and tilted and it works, i had it flat when i tested it the first time but i didint know they had the switch on theme. well ok thats good to know, ill paint it silver to make it look new and then hook it up, thanks for the insight and thanks for opening the nos one to see for me, anyone know how many years you could get these lights? i know 50's and 60's but when they stop making theme?
post #8 of 13 (permalink) Old 09-12-2011, 10:03 AM
I had one that looked "dealer installed' in a 73 riviera....Also, If you polish it with steel wool it will look like shiney aluminum. E
post #9 of 13 (permalink) Old 09-12-2011, 12:57 PM Thread Starter
yeah well my car getsdriven so i need a trunk light in case i get a flat at night so why not install one of these right? ha thanks steel whool is easyer then painting
post #10 of 13 (permalink) Old 09-12-2011, 04:24 PM
They are pretty cool! I'm puttin one in mine! E
Trunk light problem 123jboy 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 05-27-2011 10:35 AM
Trunk Light SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 05-13-2011 11:13 AM
trunk reel out light question abraxasil 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 07-06-2007 11:06 AM
Trunk light. pickinfights Service, Maintenance and Technical Discussion 7 11-11-2006 08:44 AM
Trunk Light ? lotaguts Interior Discussions 14 02-05-2006 04:11 PM
