Restoring a 1965 GTO heater box - Pontiac GTO Forum
 1Likes
  • 1 Post By Shake-N-Bake
post #1 of 4 (permalink) Old 04-02-2018, 09:45 AM Thread Starter
Quoted: 162 Post(s)
Well I tried getting help on a different section of the site, but I am guessing the only people that have restored their heater boxes are the ones in this section....Here is my latest challenge :
I have my heater box out while replacing the heater core would like to restore the box. At one point in time the heater core must have leaked and the box has some surface rust on the inside. That said, it appears the box is welded together (??). Anyone know the best way to open the box up so it can be thoroughly sanded and painted, as well as replacing the seals and gaskets (purchased from AMES) ?
Or should I NOT cut the box open and just spray the best I can on the inside and only replace the easy to reach gaskets ? Thanks
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #2 of 4 (permalink) Old 04-02-2018, 12:13 PM
Quoted: 79 Post(s)
I never had to deal with your situation before but I would consider removing the rust with electrolysis. You would need a plastic tank large enough for the part to fit. Are you familiar with that process?
Sent from my XT1585 using Tapatalk
cij911 likes this.
Shake-N-Bake is offline
post #3 of 4 (permalink) Old 04-02-2018, 02:18 PM Thread Starter
Quoted: 162 Post(s)
Thanks! The rust is mostly superficial and will come off easily in a vinegar bath. The question I have is how to paint inside and replace the internal gaskets (since the box is sealed).
Current setup:
4 speed Muncie
post #4 of 4 (permalink) Old 04-02-2018, 02:29 PM
Quoted: 79 Post(s)
Oh okay. I didn't know there were internal seals in there. Might have to take it apart then if you need to get inside....
Restoring a 1965 GTO convertible tri power cij911 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 48 03-11-2019 12:01 PM
Restoring a 1965 GTO heater box cij911 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 03-30-2018 08:46 AM
65 GTO Heater Box Heater Core Blower Motor Questions WideTrack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-06-2013 08:45 AM
heater box seals for '67 GTO with A/C TommyG67 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 02-02-2012 10:42 AM
