Rob's 1966 Restoration - Page 3 - Pontiac GTO Forum
 17Likes
post #21 of 83 (permalink) Old 11-16-2016, 07:09 PM Thread Starter
Quoted: 8 Post(s)
As you can see the body is done metal wise and in etch primer. Here are some pictures of the suspension. Went with The Right Stuff four wheel power disk all the way around. Lowered the front 2".
1966GT0 is offline
post #22 of 83 (permalink) Old 11-16-2016, 07:15 PM Thread Starter
Quoted: 8 Post(s)
I delivered the rolling chassis to the shop on Friday so it can be reunited with the body. I'll post some pictures when I get it back home. I was hoping to take it right to the shop doing the final body and paint but his shop is at capacity at the moment. I'll just keep going with the restoration of components.
1966GT0 is offline
post #23 of 83 (permalink) Old 11-16-2016, 07:47 PM
Quoted: 404 Post(s)
Looks great. I see that you added the rear sway bar - good choice. However, might I suggest that you add the upper/lower control arm braces. This will tie the 2 together and eliminate frame flex if you "use" the power of the engine. I like/used the UMI brand on my 1968 Lemans that I am rebuilding. This has been covered before on the forum's. 1964-1967 GM A-Body Control Arm Reinforcements/Frame Braces [4029] - $129.99 : UMI Performance, Inc. It is a bolt-in with all the parts you need - very easy. These arms have a slight bend to them to clear the floor pan as some brands can hit and you might have to do a little floor adjusting with the hammer. They are also adjustable so this makes it real easy to get your bolts lined up as frames/mounts are not always perfect.
Here is a lesser expensive version, and a copy of what the factory offered on the 4-speed cars, but they have no adjustments should you have any frame issues and they are not as heavy-duty as the UMI pieces. They don't need any additional bolts like the UMI set as they are flat stock and you would use your existing control arm bolts. There is nothing wrong with these and they are certainly better than no braces. https://www.yearone.com/Product/1964...99#prettyPhoto
Just a suggestion.
post #24 of 83 (permalink) Old 11-16-2016, 08:28 PM Thread Starter
Quoted: 8 Post(s)
Thanks Jim,
I'll take all the suggestions you have. The car is actually a four speed just haven't got the new floor cut yet. It has the factory reinforcements but I'm going to have a closer look at those UMI parts. I have used their stuff before and it's great.
Thanks, Rob
1966GT0 is offline
post #25 of 83 (permalink) Old 12-25-2016, 06:45 PM Thread Starter
Quoted: 8 Post(s)
She is mated back to the frame. Here are a few pictures. All metal now, rust is completely gone. Unfortunately I had to bring it back home instead of right to the painter. He is booked up, I'll start detailing components and wait my turn. He does beautiful work so it's worth the wait.
1966GT0 is offline
post #26 of 83 (permalink) Old 01-19-2017, 09:10 PM Thread Starter
Quoted: 8 Post(s)
Well I got the call from the painter last week! Delivered it to his shop last night. Now I have some room in the garage to work on the components. I'll post some pictures as he progresses.
1966GT0 is offline
post #27 of 83 (permalink) Old 02-01-2017, 10:13 PM Thread Starter
Quoted: 8 Post(s)
Pics from body shop
Got just a few pics from the body shop today. Looks like he is making good progress towards getting it straight.
ID:	86386   Click image for larger version
ID:	86394   Click image for larger version
1966GT0 is offline
post #28 of 83 (permalink) Old 02-05-2017, 08:47 AM
Quoted: 4 Post(s)
wow
looks awesome it is a real inspiration
zsowhat is offline
post #29 of 83 (permalink) Old 02-12-2017, 01:36 AM
Wickedgoat's Avatar
Quoted: 6 Post(s)
Wow. I'm new here. This is fantastic. I can't wait to see the paint!
"Never, ever, scratch a tiger's balls with a wire brush."
Wickedgoat is offline
post #30 of 83 (permalink) Old 02-23-2017, 11:14 PM Thread Starter
Quoted: 8 Post(s)
Here are a few recent ones from the body shop. Just about finished the the fine work and ready for final primer. Lots of hours to get to this point.
ID:	87786   Click image for larger version
ID:	87794   Click image for larger version
ID:	87802   Click image for larger version
ID:	87810   Click image for larger version
1966GT0 is offline
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
1966 gto interior restoration questions paratrooper82 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 07-18-2012 09:32 PM
1966 GTO Restoration jaymay75 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 12 02-21-2012 10:50 PM
1966 restoration MyOldGoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 01-24-2012 07:24 PM
1966 GTO Grill Molding Restoration tigergoldpost 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 09-16-2009 04:35 PM
Hey, its Rob Itsrobbie Member Introductions 1 08-06-2009 12:14 AM
