sandblasting advice - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-15-2012, 06:27 AM Thread Starter
sandblasting advice
Guys,
I've been sandblasting different parts of my Goat with "black beauty", but I'm not sure if I should use it on the insert for the hood scoop, and the housings for the tail lens. Specifically, the "fins" of the scoop (not the technical name, I know, the horizontal "bars", if that's a better explanation) are what concern me. I blasted the rest of it, and that part is fine. The tail lens housings seem like a lighter material, so I want to be sure before I go forward.
Any suggestions, as always, are appreciated.
pbertrand65GTO is offline
post #2 of 4 (permalink) Old 01-15-2012, 05:56 PM
Black beauty works real nice.Try dusting it. Dusting is when you sand blast it at an angle from a further distance. Take a few steps back from the scoops blast it adjust your distance as needed to get the right distance just until the paint begins being removed. Try lowering your air pressure?
post #3 of 4 (permalink) Old 01-15-2012, 06:53 PM Thread Starter
Thanks Judge, I'll give that a try.
BTW, Your car is stunning!
post #4 of 4 (permalink) Old 01-16-2012, 08:57 AM
Good luck . and......Thank You
sandblasting frame Logchain 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 10 01-04-2012 08:20 PM
Need some advice GM4life 2004-2006 GTO General Discussion 11 06-07-2010 10:59 AM
New here, need advice 02whitele Member Introductions 3 02-24-2006 02:16 PM
comparison the "cant break 8s" b4 advice and after the advice DK2F Service, Maintenance and Technical Discussion 0 02-11-2006 03:09 AM
