solution to removing rust where sand paper won't fit - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-14-2013, 03:09 PM Thread Starter
i'm sanding the under side of my trunk lid right now and there is some surface rust in the seem where the outside piece folds over the bottom piece. i can't get to it with sand paper and i don't have a sand blaster so i'm wondering if there is a solution to removing this rust. my local auto parts has rost oleum rust stripper, does anyone have experience with this and if so would that be a remedy to my problem?
woolsey10 is offline
post #2 of 5 (permalink) Old 10-14-2013, 03:27 PM
68greengoat's Avatar
Wire wheel?
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 5 (permalink) Old 10-14-2013, 09:18 PM
skurfan's Avatar
Can a Dremel help you? Very tedious but helpful in tight areas. Or if it's up under, hit it with rust converter.
skurfan is offline
post #4 of 5 (permalink) Old 10-15-2013, 08:29 AM
Try a product called Ospho, treat the metal and then spray with an epoxy sealer/primer.
05GTO is online now
post #5 of 5 (permalink) Old 10-15-2013, 09:30 AM
Flip the lid around so it runs into the seam and not just wipe it on the seam..
Sand Blasting Your Car HaloPlayer 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 07-30-2013 08:45 PM
Anyone know what this piece of paper is? MO Goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 03-30-2012 10:55 PM
RE: Goat's In The Paper PDQ GTO The Lounge 5 02-22-2009 08:41 PM
How much sand? muohio 2004-2006 GTO General Discussion 18 12-29-2004 07:20 PM
paper work done, will pick up Tuesday :) sunny 2004-2006 GTO General Discussion 8 09-24-2004 06:55 AM
