Some more progress - Pontiac GTO Forum
post #1 of 21 (permalink) Old 04-28-2012, 10:42 AM Thread Starter
Some more progress
Got a lot of plumbing, wiring, and etc. done...starting to look like a car!!
ID:	14602   Click image for larger version
ID:	14603   Click image for larger version
ID:	14604   Click image for larger version
ID:	14605   Click image for larger version
Eric Animal is offline
post #2 of 21 (permalink) Old 04-28-2012, 02:26 PM
68GTO4004Spd's Avatar
I can't wait to see the video of that car doing an asphalt ripping burnout. Outstanding job.
68GTO4004Spd is offline
post #3 of 21 (permalink) Old 04-28-2012, 02:59 PM
Quoted: 23 Post(s)
very nice E....hey seeing that made me wonder, what type of distributor did you use with the blower, will the HEI fit, i ask because i picked up the low profile dual quads and am not sure if i will have to go with a smaller unit?
Instg8ter is offline
post #4 of 21 (permalink) Old 04-28-2012, 05:05 PM
crustysack's Avatar
All passengers shall were seat belts during the full duration of the flight.
That looks so sweet. What kind of lights are those? (you might have answered this already)
crustysack is offline
post #5 of 21 (permalink) Old 04-28-2012, 07:56 PM Thread Starter
Inst, The distributor is a MSD unit, the HEI is too fat to fit...that MAY be the case with your 2x4 also......
Crusty, The headlights are Halogen NOT Zenon. They also have halos...the brand is...I don't remember and the box is plain white.....I got them by doing an E-bay search for: 5 3/4" halogen halo lights. A Chevelle kit came up. You will have to ream out the back of the headlight buckets a bit to install them....They ARE VERY Bright. 68, I can't wait to do a burnout either. I'm gonna vaporize my driveway first thing!!! Eric
post #6 of 21 (permalink) Old 04-29-2012, 10:51 AM
Very nice E!
Man, that blower belt is pretty tight to the fans, ain't it?
Hey Brian, if you want an HEI style ignition but are concerned about clearance, check these out:
GM Tri-Power Ignition
BearGFR is online now
post #7 of 21 (permalink) Old 04-29-2012, 11:06 AM
Quoted: 99 Post(s)
Eric, is your Prius the same color as the goat??
post #8 of 21 (permalink) Old 04-29-2012, 08:00 PM Thread Starter
Bear,Yes it is!!!....3/4"...very solid and SHOULDN"T move ! JEFF, What's a Prius? Eric
post #9 of 21 (permalink) Old 04-30-2012, 03:58 PM
Pontiacpurebrred's Avatar
Originally Posted by Eric Animal View Post
Crusty, The headlights are Halogen NOT Zenon. They also have halos...the brand is...I don't remember and the box is plain white.....I got them by doing an E-bay search for: 5 3/4" halogen halo lights. A Chevelle kit came up. You will have to ream out the back of the headlight buckets a bit to install them....They ARE VERY Bright. Eric
Wow the car looks.... well, incredible. I am in awe
This was a very timely post and discussion. I had been looking for an alternative to the standard headlights (Especially after hearing about the connection issues with new bulbs old harness.) I found the 5 3/4 projector halos and was afraid I might be crazy thinking halos would look cool on a 69 Custom-S, I feel a bit better with the comments here but it does bring up a question. Are all 4 of yours low beams? Or are 2 hi beams? I couldn't find a listing for hi-beam lights in this style.
As always, Thanks Eric!
Scott
2005 GTO Daily Driver
1969 Custom-S Project car
1971 GTO 455 in process of rebuild TH400 NEED A NEW REAREND!!!
Pontiacpurebrred is offline
post #10 of 21 (permalink) Old 04-30-2012, 06:00 PM Thread Starter
Scott, The lights are all basically low beams...they will still work the same way, as they come with harness adaptors. When the low beams are on, only2 lights will light ...when the high beams are on, all 4 will light. You MIGHT need to cut the backs of the headlight buckets out (a 3.5" hole saw works well)..... Eric
65 progress crustysack 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 11-30-2013 08:38 PM
65 progress crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 08-12-2010 09:43 AM
65 progress crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-24-2009 09:02 PM
More progress ??!!?? Too Many Projects 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-09-2009 06:57 PM
Car Progress so far.... blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 08-01-2008 12:21 PM
