Some resto Q's - Pontiac GTO Forum
post #1 of 22 (permalink) Old 01-26-2012, 03:33 PM Thread Starter
Hot_Rod's Avatar
Some resto Q's
So today I decided to decode my car and try to unlock some factory details about it. Like the original colors, options and etc.
I tried to look up interior color and I got a 241. I looked it up on ultimategto.com and there is no 241 code listed for '70 but WAS listed for 72's and noted it was also a bench seat. This is confusing cause the codes indicate it IS indeed a '70 Lemans though. Maybe it wasnt listed on their site?
Cause I know my car was a blue interior car with a bench seat(supposedly cloth seat also) along with a column shift. Thoughts on that?
Car was atoll blue with blue interior and bench seat fyi. May be restoring it back to factory. My interior is black though as the guy I got it from had started a black interior swap. I love the atoll blue and blue look.
Ok my next question: Sadly I have no garage atm to keep my car in. When it rains or pours the floorboards get soaked in standing water. It leaks a lil by the weatherstripping on the a-post but I'm not sure it leaks that bad. It seems to me like it could be a leak under the dash area..What are the common places for water leaks in those areas? (i'm afraid it could be the r word) A friend who restores 442's told me these cars are bad about rust under the cowl/winshield area. (lord I hope not)
Thoughts?
Jarred "Hot Rod" |1970 Pontiac LeMans Sport | Just a 350...
Hot_Rod is offline
post #2 of 22 (permalink) Old 01-26-2012, 05:03 PM
Roger that's Avatar
My book shows the code 241 as a medium blue morrokide bench seat in the Lemans coupe (code 3527) and hardtop coupe (code 3537) for the year 1970. No 241 code was listed in my book for the GTO.
Roger that is offline
post #3 of 22 (permalink) Old 01-26-2012, 05:28 PM Thread Starter
Hot_Rod's Avatar
Cool thanks.
Hot_Rod is offline
post #4 of 22 (permalink) Old 01-26-2012, 05:36 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
You need to get out there while it is raining and trace that leak! Sooner than later, could be a number of areas.
FlambeauHO is offline
post #5 of 22 (permalink) Old 01-26-2012, 05:58 PM
Yep, probably. There's sort of a shelf all along the bottom edge of the windshield that's shaped such that it's pretty bad about catching and retaining water. It's a common spot for rust. Have a buddy play the stream from a garden hose back and forth across the top of the windsheild while you look up from underneath the dash. You'll probably see it coming in.
post #6 of 22 (permalink) Old 01-26-2012, 05:59 PM Thread Starter
Hot_Rod's Avatar
I know it leaks some around the a posts by the winshield. But other than that I wasn't able to see where it leaked.
Hot_Rod is offline
post #7 of 22 (permalink) Old 01-26-2012, 06:02 PM Thread Starter
Hot_Rod's Avatar
Yeah I'm afraid of that. Cause that would mean this thing will need serious attention as far as restoring it. If it is coming from there is it bad? What will I have to do to fix that?
Hot_Rod is offline
post #8 of 22 (permalink) Old 01-26-2012, 08:45 PM
jetstang's Avatar
My 70 leaked in through the kick panel vents for the heater/vent. The rockers were full of leaves and dirt. I took my cowl screens out and flooded the car with a hose and watched where the the water came in from.
I used my shop vac and ran it down into the lower fenders to vacuum out the leaves and crap, then flushed it out, but then the crap runs to the back of the rocker. There are holes in the rocker that you can fish crud out of in front of the wheels, make sure it's draining back there. You can remove the vent/return from under the kick panel to get access, but on AC cars this is the air return and is hard to hook the hose back up. For that, you can remove the blower motor through the passenger side wheel well, chiltons gives instructions on hacking a hole in the inner fender to get blower access. Remove the blower and clean out the rocker.
Good luck, my car didn't have any rust, but did leak into the car.
Burning rubber since 1982!!
jetstang is offline
post #9 of 22 (permalink) Old 01-26-2012, 09:23 PM Thread Starter
Hot_Rod's Avatar
Geez. Sounds like a pain, lol. Btw, not sure how much if any this may play a rol but none of my ac components are in the car. At least not the box for the vents that hooks into the firewall.
Other than that, idk what all is still in the car for the hvac.
Hot_Rod is offline
post #10 of 22 (permalink) Old 01-27-2012, 04:50 AM
I had that problem on the Beast and it actually wasn't all that bad to fix. The unpleasant part was getting it down to where I could. Everything along the base of the windshield area has to come out, and also the windshiield itself, to expose all the metal in the area so you can see it. It's not all that hard to make and weld patches in there, but of course you've got to make sure there's nothing close by that can catch fire when you do, including on the inside of the car under the dash.
Some resto Q's Hot_Rod 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 22 07-15-2011 07:07 PM
Resto help geeteeooh 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 03-31-2011 02:09 PM
67 Resto progress Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 05-11-2010 07:49 PM
More 67 resto pics Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 04-17-2010 12:17 PM
'67 resto mountain goat 1964-1974 Tempest, Lemans & GTO General Discussion 0 02-03-2005 10:34 PM
