Started laying out the fuel system - Pontiac GTO Forum
post #1 of 14 (permalink) Old 03-28-2011, 08:20 PM Thread Starter
We started to lay out the fuel system....repro stainless tank.....Rob Mc sender/feed/return....Aeromotive pump and filters....-8AN going to the carbs....-6AN coming back to the tank. The lines themselves will be part 1/2" stainless tubing, and part Aeroquip braided stainless line.
Eric Animal is offline
post #2 of 14 (permalink) Old 03-28-2011, 08:34 PM
crustysack's Avatar
nice, VERY nice
crustysack is offline
post #3 of 14 (permalink) Old 03-28-2011, 08:50 PM
Looks awesome Eric...is that a 4 link I see as well?
GTOcop is offline
post #4 of 14 (permalink) Old 03-28-2011, 09:24 PM Thread Starter
Thanks fellas ...yes a custom 4 link !
ID:	10678   Click image for larger version
post #5 of 14 (permalink) Old 03-28-2011, 09:54 PM
That's bad ass Eric...I can't tell from the pics...is it adjustable?...either way it looks great
GTOcop is offline
post #6 of 14 (permalink) Old 03-28-2011, 09:54 PM
I like RobbMc stuff. I'm using his pump, filter, regulator, and starter. With that blower motor and as much power as it's going to make, I'm curious why you're not putting a sump into the fuel tank?
post #7 of 14 (permalink) Old 03-29-2011, 08:45 AM Thread Starter
GTOcop, yes all the links and suspension parts are adjustable. BEAR, I was thinking about a sump, but was advised I don't really need one. The tank is baffled......
post #8 of 14 (permalink) Old 03-29-2011, 11:58 AM
They make baffled tanks??? Well, strip my gears and call me shiftless... If I'da knowed that, I coulda saved myself some grief and my bride some more gray hairs (from me welding a sump into my original tank...)
"Honey, if you hear a loud noise here in a few minutes, don't go outside - just call the fire department and an ambulance... ")
Where'd you get it?
post #9 of 14 (permalink) Old 03-29-2011, 12:32 PM
thats an interesting rear suspension. i have experience in circle track suspension fabrication and design and i cant understand why someone would design a suspension with those angled upper arms. i am sure there is a good reason but it seems to me it would be more efficient to run the arms straight ahead and use a panhard bar for side to side location. can you tell me the theory behind that design?
freethinker is offline
post #10 of 14 (permalink) Old 03-29-2011, 12:49 PM
Hey Eric, am I hallucinating again or did you originally have a Watts Link in that chassis?
@freethinker... the triangulated non-parallel upper arms also locate the axle side to side, doing the job a panhard bar would do. The down-side is that unless the ends on those upper arms can swivel (the factory ones don't but many aftermarket replacements do, and it looks like Eric's probably do too) the upper arms can "bind" and resist allowing the axle to freely move in a body roll situation like in a corner. The factory triangulated arms used rubber bushings everywhere so they could deform and allow some roll movement, but they still bound up. As a panhard bar moves up and down through its arc, the axle moves from side to side a little bit. With a Watts Link, that doesn't happen. The axle stays located in the same spot side to side but is still free to articulate in all the directions it needs to.
OK, Lets get started........ MAXXFJ 1964-1974 Tempest, Lemans & GTO General Discussion 19 10-15-2010 03:22 PM
fuel system 90% done/ custom intake crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-24-2010 03:28 PM
need help i.d.ing a Q-jet i got laying around danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-26-2009 11:49 PM
Anyone, stock exhaust laying around? Silver Bullet Intake and Exhaust Discussions 12 07-02-2007 05:54 PM
GM is laying off 25,000 people johnnytuinal 2004-2006 GTO General Discussion 16 06-22-2005 12:53 PM
