Starting work on the 66 GTO! - Pontiac GTO Forum
post #1 of 12 (permalink) Old 12-17-2015, 06:36 AM Thread Starter
This is my first post outside the introduction thread. I have owned muscle cars since I was 13 years old and have loved them all for all different reasons. This is my first GTO and am very excited to get started on it. It has been sitting in a garage for what the 2nd owner tells me is about 17 years! I dug it out of it's hiding place wedged between washing machines, refrigerators, bikes etc! Luckily it was inside out of the weather.
From what the owner told me, it has a 400 from a '70 GTO and the original Muncie 4 speed transmission. This weekend I am going to take a good look at the top end and bottom end of the motor, the fluids, wiring and if everything looks to be in good shape, I'll got through the normal "barn find" checklist and see if I can get it started!
Plans for now are to get it running and driving, work on the interior and get the body work done slowly. Rust in minimal on the body, but it will need floors in the rear. It's not going to be a frame-off, just a nice driver. My problem is, when I make a car too nice, I don't drive it
ID:	68618   Click image for larger version
Ed-PV is offline
post #2 of 12 (permalink) Old 12-17-2015, 05:07 PM
Quoted: 368 Post(s)
I might just leave the body as is and put a sealer on it to keep the worn "rat-rod" look. Then I would do any floor repairs and then go through it front to back doing brakes, updating to front discs & master cyl., rebuild the suspension, add front & rear sway bars for handling, and then build a moderate HP 461CI using your present engine and a rotating stroker kit.
post #3 of 12 (permalink) Old 12-17-2015, 05:45 PM Thread Starter
Hey Jim, LOVE the idea! I was thinking along the same lines. I had some time today so I went ahead and rebuilt all the brakes and put on a new booster and Master! I am trying to get it running and driving as soon as I can since the weather is nice in Florida
Ed-PV is offline
post #4 of 12 (permalink) Old 12-17-2015, 05:50 PM Thread Starter
A better picture of the engine before I start working on it.
Ed-PV is offline
post #5 of 12 (permalink) Old 12-20-2015, 05:40 PM Thread Starter
I spent the weekend working on the GTO! I pulled the top end of the motor apart and everything looked surprisingly good! I cleaned everything up, put in new gaskets in where needed, painted and put it all back together. I was also able to put in a new brake booster, master and changed lines where needed. While working on the brakes, i replaced all the wheel cylinders and pads.
I set the distributor to 12 deg BTC after priming the oil pump and IT STARTED RIGHT UP!!!
For one muffler being blown out, it sounds really good! I took it for a yard drive and was all good. It has been a while since I have driven a V-Gate 4-speed shifter, but it came back quickly
Next step is to fine tune the timing and carb and take it on the road!
Here is a video of the motor running...
https://goo.gl/photos/CF4cKk2tDhhxFKQD6
Ed-PV is offline
post #6 of 12 (permalink) Old 12-20-2015, 06:37 PM
Quoted: 368 Post(s)
Sounds like good progress. You don't have to restore the car to enjoy it. I'd do what I can to tackle any rust problems so they don't continue to rot. I ran my '68 Lemans like that, grey primer, dents, surface rust, ratty interior, etc., but rebuilt the chassis components, engine, new clutch, exhaust, etc. Drove it about 7-8 years. Now I am doing the long term frame off rebuild that will be more hot rod than anything original. I just hate it as it is probably going to be a 5-7 year project whereas before I was driving it.
post #7 of 12 (permalink) Old 12-20-2015, 06:49 PM Thread Starter
Yes, I like driving them too much to wait for a restoration I only have one car that I don't drive in the rain...my '69 Mach 1 that I bought when I was 13 and recently did a full restoration on.
Ed-PV is offline
post #8 of 12 (permalink) Old 12-20-2015, 06:53 PM Thread Starter
The front end looks high to me, thinking about putting in some 2" lowering springs in front and finding some nice wheels/tires.
Ed-PV is offline
post #9 of 12 (permalink) Old 12-20-2015, 07:27 PM
Lemans guy's Avatar
Quoted: 56 Post(s)
Really like your car! I also agree to get it driving...reliable and enjoy it...
Clear coating and keeping that old look can be too cool for school!
You are on the right things already....you should have a blast...
Too perfect is not always as fun!
Lemans guy is online now
post #10 of 12 (permalink) Old 12-27-2015, 07:14 PM Thread Starter
Had some Weld Race Stars in the garage...tried them on and they look pretty good! I am really thinking I need to lower the front end...will do some research on lowering springs vs. drop spindles.
Ed-PV is offline
Starting problems after some work NEEDLEZ 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-07-2011 10:27 PM
Starting Work on a 67 Convertible jwduggan 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 07-10-2011 10:05 AM
got a little work done today. floor work virginiavenom 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 07-02-2011 12:06 AM
starting body work Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 34 01-14-2011 08:59 PM
[Freebies] How they work, why they work & how to work them. Last The Lounge 1 01-09-2005 07:15 PM
