Tell Me About Steel! - Pontiac GTO Forum
post #1 of 18 (permalink) Old 01-15-2010, 04:25 PM Thread Starter
What type of steel (carbon content and gauge) was used in trunk floors and quarter panels in 1965? And where can I buy that type of sheet steel on line to use as patch material?
Thanks!
WideTrack is offline
post #2 of 18 (permalink) Old 01-15-2010, 04:44 PM
Why not just buy a trunk kit and then not only is the gauge and everything correct, but it has all the dents and dimples, gas tank brackets and frame mounts ready to go?
post #3 of 18 (permalink) Old 01-15-2010, 05:13 PM Thread Starter
I only have a couple small holes that I want to try to fix myself. I'm not confident enough in my welding ability to put the whole trunk kit in.
post #4 of 18 (permalink) Old 01-15-2010, 07:59 PM
66tempestGT's Avatar
considering that the original metal didnt do a very good job of holding up, i wouldnt spend a lot of time trying to duplicate it exactly. on the other hand im sure that someone on here can come up with some original 1965 partially rusted trunk metal that will match what you have left exactly.
66tempestGT is offline
post #5 of 18 (permalink) Old 01-15-2010, 08:02 PM
seriously, just pick up an old bent fender or something and cut out what you need. stop by any body shop they will have a big pile.
post #6 of 18 (permalink) Old 01-15-2010, 08:38 PM
It is called tin actually in the scrap metal business.
Unclesams is offline
post #7 of 18 (permalink) Old 01-15-2010, 10:17 PM
67 Basket Case Restorer
Too Many Projects's Avatar
He's not going to find anything in a modern body shop scrap pile to compare to a 65 car. It's all tin foil today. Your idea about someone on here contributing removed metal is good. I just cut out a piece of my 67 trunk floor yesterday. It's about 2 1/2"wide by 6-7 long. Will that be enough for 1 or 2 patches ? I have a piece of interior floor I cut out last year too. I can't remember just how big it is but it's bigger than the trunk piece. Let me know if you want exact sizes and pics. Pieces are free, just pay the shipping.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #8 of 18 (permalink) Old 01-15-2010, 11:11 PM
i dont really know what difference it makes. a wrecked f-250 bedside or dodge ram is just as thick if not thicker. besides how much weight are you going to put in there?
post #9 of 18 (permalink) Old 01-16-2010, 08:02 AM
It dont really matter what source it comes from' trunk metal is usually 16 -18 gauge (thickness). If its only small areas buy new sheet metal in the according size (not expensive). Dont use old rusty steel' defeats object unless its very clean stuff. note: 18 gauge is hard to shape by hand if creases are needed .
Gran Turismo is offline
post #10 of 18 (permalink) Old 01-16-2010, 10:01 AM Thread Starter
Thanks Mitch, but I may need something little bigger. There are plenty of junk yards around here (I'm in Detroit) so I can take my pick of fairly old metal if I go that route. I was just wondering if it was easier/better to use the old stuff or the lighter gauge stuff I can buy at the hardware store. I thought I'd have to use 16 gauge. The holes I'm patching are above the trunk floor braces that hold the cage nuts for the body mounts, so I didn't know if I needed to use older style heavier gauge metal for those spots since they are somewhat "load bearing".
I didn't think of the bodyshop for wrecked pick-up truck bed sides....that might work too.
Thanks for the help guys.
rust and steel wool...... asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-07-2008 12:27 PM
Stainless Steel Tanks? 5hundo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-07-2008 06:07 PM
Dumped 15 Pounds of Useless Steel b_a_betterperson 2004-2006 GTO General Discussion 14 03-27-2007 02:37 AM
