TH400 speedometer drive gear clip - Pontiac GTO Forum
post #1 of 1 (permalink) Old 06-20-2015, 05:37 PM Thread Starter
I pulled my extension shaft housing to see what was going on with my speedometer.
The drive gear clip is missing (could be in the pan I know) but if it came off I want to make sure whoever put it together used the right clip anyways.
I need to get a speedometer drive gear clip but can't find it anywhere local or online. I see the long and skinny type online which looks the specs say it is about 5/16" wide which I don't think is correct because by drive gear slot is about 1/2" wide.
I saw one that was called a short and wide one that I bought but that is not it either, that one is not wide and is too short (length)
Is it the long and skinny one I need even though my drive gear has a bigger groove? won't it be too much play?
I had removed my drive gear out of a th350 in a different car that had the long and skinny clip but that drive gear groove was smaller than this one.
What is going on here? what clip? or wrong gear?
michaelrj9 is offline
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 03:48 PM
Muncie speedometer gear SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-08-2012 07:03 PM
Speedometer gear gtoearl 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-22-2009 08:00 AM
Speedometer Gear Question jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-16-2007 09:28 PM
need help getting the right speedometer cable gear ergo Service, Maintenance and Technical Discussion 2 05-07-2006 09:04 AM
