Today's the day... - Pontiac GTO Forum
post #1 of 78 (permalink) Old 06-11-2011, 02:35 PM Thread Starter
Today's the day...
Car is masked, clean, and I'm waiting right now for the induction period on the sealer so I can start applying it.
With a little luck and the Lord willin', today's the last day anyone will see this GTO "nekkid".
post #2 of 78 (permalink) Old 06-11-2011, 02:54 PM
Good luck Bear! If you have any energy left, let us know how you did!!! Eric
Eric Animal is offline
post #3 of 78 (permalink) Old 06-11-2011, 04:17 PM Thread Starter
Sealer's on. I've got some ooops spots to fix but nothing that's too bad, I don't think. One small run on the passenger door by the A-pillar, one spot where the hose got into it and another where a big ol' sweat drop landed on the trunk lid right at the edge of my spray pattern - argh! Mostly ok I think. I'm going to give it an hour or so and see if I can gently wet sand those spots out so I can continue with color.
I keep telling myself not to expect perfection on my first paint job, otherwise I'm never going to get this thing done.
post #4 of 78 (permalink) Old 06-11-2011, 05:44 PM
68GTO4004Spd's Avatar
Keep at it man, you will get r done. You did pick one of the hardest colors to get right, so give yourself some slack. Remember that you are going to have a grin on your face that can't be slapped off when your done.
68GTO4004Spd is offline
post #5 of 78 (permalink) Old 06-11-2011, 06:58 PM
jetstang's Avatar
You ran the sealer? Good luck with the paint, you can always cut and buff.. It should go good. And you can always sand and redo, hopefully you went non metallic paint. Wear a do rag to catch the sweat, I have sweated on a couple cars myself, not fun..
Burning rubber since 1982!!
jetstang is offline
post #6 of 78 (permalink) Old 06-11-2011, 09:05 PM Thread Starter
Yeah, I did. I was trying to make sure it got down the A-pillar behind the door and tarried just a tad bit too long.
Everything's fixed though, and the first coat of color is on with nary a mistake nor a run. I bought some "coverage" tape that has a checkerboard pattern on it you can use to tell when you've got hiding. One coat darn near did it, and I wasn't putting it on heavy either - "medium wet" just like the doctor ordered. PPG's tech sheet for this stuff says "two medium wet coats" and man they ain't kidding.
Can't wait to see what the clear does.
ID:	11388   Click image for larger version
ID:	11389   Click image for larger version
ID:	11390   Click image for larger version
post #7 of 78 (permalink) Old 06-11-2011, 09:23 PM
Nice job!
05GTO is online now
post #8 of 78 (permalink) Old 06-11-2011, 09:23 PM
SDGoat619's Avatar
looks great, what brand paint did you go with
65 LeMans, 455,TH400, Edelbrock preformer Intake&Carb, K&N Filter, Custom Headers & Dual Exhaust W/ H pipe, 15in ralley wheels...... More to come.
SDGoat619 is offline
post #9 of 78 (permalink) Old 06-11-2011, 11:12 PM Thread Starter
It's PPG DBC 9700, activated with their DX57 hardener, with Southern Polyurethanes slow reducer. When my supplier went to look up how to mix the color, it turned out that there's no mixing - it's just pure black base.
I just finished up the 2nd coat. I reviewed the tech sheet one more time and it says "2-3 coats or until hiding is achieved. Avoid thick films of DBC". I might go with one more depending on how this one looks after it flashes. I'm planning on 4 coats of clear. It's going to be a long night
Addendum: putting on one more coat of base was definitely the right thing to do. It's really starting to get there.
ID:	11392   Click image for larger version
post #10 of 78 (permalink) Old 06-12-2011, 06:53 AM
Quoted: 23 Post(s)
lookin good Bear, those 4 coats clear are gonna make it deep and leave plenty of meat for wet sanding, after a week and a half i have to lean into it to get the clear to cut with 1500 and no worries about sanding through by hand. Looking forward to seeing it shine later today i know you had a smile on your face when you hit the sack.....
Instg8ter is offline
very good day ilovemytt Member Introductions 6 06-26-2010 01:39 AM
Today's the day xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 28 11-02-2009 03:30 PM
1-1, But Still a Good Day phantomblackgto Racing and Kill Forum 1 10-14-2006 09:42 PM
Day One goatzilla Member Introductions 0 08-05-2006 09:02 AM
This day just got better. redrocketgto 2004-2006 GTO General Discussion 1 11-18-2005 09:20 PM
