Trans # help - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-02-2011, 08:58 PM Thread Starter
Send a message via Yahoo to mikey gto
Trans # help
These are the # on the 4 speed trans I have,Can someone tell me what trans this is ?
case#3885010
this # was hard to see but it looked like 6k115304
mikey gto is offline
post #2 of 7 (permalink) Old 12-03-2011, 11:33 PM
these nos. have no meaning for identification.
pontiac is offline
post #3 of 7 (permalink) Old 12-04-2011, 01:59 PM
3885010 is the casting number for a 1965-1967 Muncie, 2 input rings would be a M-20, 1 input ring would be a M-21.
M-20 Ratio= 1st-2.52, 2nd-1.88, 3rd-1.46, 4th-1.00 and rev.-3.11
M-21 Ratio= 1st-2.20, 2nd-1.64, 3rd-1.28, 4th-1.00 and rev.-2.27
6k115304- 6=1966, K is for the assemble plant whick may be Kansas, 115304 is the build sequence of the car and may also be part of the car's vin number.
05GTO is online now
post #4 of 7 (permalink) Old 12-04-2011, 02:55 PM Thread Starter
So this would be a correct 4 speed for a 67 gto ?
post #5 of 7 (permalink) Old 12-04-2011, 03:49 PM
Depends on the date code, in 66 the date code would be "P0106" P=Muncie Plant 01=January and 06 would be the 6th day.
In 67 the coding changed to P7A06 P=Muncie Plant, 7=1967 A=January and 06 would be the 6th day.
05GTO is online now
post #6 of 7 (permalink) Old 12-05-2011, 05:37 PM Thread Starter
So where would i find the correct # on the trans other then the 2 I listed ? I am going to sell this trans and I dont want to tell someone it's a 67 and it's not.
post #7 of 7 (permalink) Old 12-05-2011, 06:06 PM
Here is a website with Muncie information, there should be several casting numbers and date codes on the transmission to help you determine the correct year, good luck,
http://members.tripod.com/camaro_obsession/muncie.htm
05GTO is online now
350 Trans into a Manual Trans on a 1970 Pontiac Lemans 93fbird 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-12-2010 08:32 PM
Trans I.D. Help!! bnichols04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 08-08-2010 09:30 PM
06 Gto Vs 02 Trans Am W5.6 Ram Air raphtime Racing and Kill Forum 9 07-29-2007 10:38 PM
