?transmission - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-04-2011, 03:06 PM Thread Starter
?transmission
We bought a 1967 Lamans needing a complete restoration. I found a 400 engine out of a 69 Granprix but we still need a transmission for it. What length tail shaft should it have on the transmission? We have the original 67 driveline.
thanks,
Tom
tomstoyflyer is offline
post #2 of 5 (permalink) Old 01-06-2011, 08:18 AM
allpawl66's Avatar
If you have your original drive-line , use the trans. from that .
allpawl66 is offline
post #3 of 5 (permalink) Old 01-06-2011, 08:38 AM
Quoted: 23 Post(s)
stick or auto? what type of driving do you plan, strip, highway, just cruising? what is your rear end gear currently? Could be anything from Power glide two speed to newer overdrive auto conversion or any number of manuals. the more info the more concise the answers.
Instg8ter is offline
post #4 of 5 (permalink) Old 01-08-2011, 10:50 AM
700R4 or 200R4 or Trubo 400. All you need to do with the R4's is change the tail shaft. I've done two. 400 will bolt right in. Don't know on manual.
bullet20cc is offline
post #5 of 5 (permalink) Old 01-10-2011, 09:59 PM
bobby326's Avatar
im putting in a 700r4 in my 67 lemans take a look ar monster transmission. they have a conversion kit for 2000. thats what in going with. im getting the ss package
bobby326 is offline
Another Transmission ID MaL 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 07-15-2009 09:44 AM
Transmission ID bkellis1 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-13-2009 03:08 PM
What transmission do I have? ironworker111 Drive train, suspension, alignment and brakes. 1 05-31-2009 08:47 AM
Transmission gone meg30_68 Drive train, suspension, alignment and brakes. 10 01-15-2008 07:18 AM
Transmission Help Todd6790 Service, Maintenance and Technical Discussion 25 01-04-2005 10:16 AM
