transmission crossmember question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-08-2012, 03:20 PM Thread Starter
I have a 67 GTO and I got it half restored. It came with a new transmission crossmember but i have no idea how it goes in. The crossmember has no holes and I cannot see anything on the frame rails that this can go into. Am I missing something? Can anyone help me out here?
SammyLJ is offline
post #2 of 2 (permalink) Old 03-08-2012, 03:34 PM
rickm's Avatar
Quoted: 5 Post(s)
you need to get a set of crossmember rubber insulators and brackets that mount on the ends and are attached to frame with bolts. if you look on the frame on both sides you will see the existing bolt holes with same pattern as brackets. if i can make a suggestion get the parts from ames performance and also get a chassis shop manual. its well worth it. rickm.
rickm is offline
Another transmission question Al T 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 11 06-05-2013 08:25 AM
Another Transmission Question Al T 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 11-01-2010 05:27 PM
Question about '68 transmission Poncho Dan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-11-2010 10:47 AM
'68 Transmission question Edelberg16 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 11-08-2008 07:20 PM
Transmission Question ncgoat Service, Maintenance and Technical Discussion 5 11-06-2005 06:52 PM
