Trunk rubber seal problems - Pontiac GTO Forum
post #1 of 13 (permalink) Old 12-23-2010, 09:14 PM Thread Starter
1966 GTO back from frame off restoration. Trunk lid body gap lines are great, but trunk lid will not shut tight enough to be all the way flush with rear quarters. Told that rubber seal will soften with time and correct this problem. Make sense? Any thing that can be done to soften seals?
BWGoat is offline
post #2 of 13 (permalink) Old 12-23-2010, 11:27 PM
makes no sense. do they have it in backwards? the lip is supposed to point out.
freethinker is offline
post #3 of 13 (permalink) Old 12-24-2010, 09:44 AM
Quoted: 117 Post(s)
No Sense at all. Paying good money to have a job done and having to accept explanatins of why it's not quite right, but will fix itself in time, is pretty much a cop-out. It has the wrong seal installed. The correct seal is about 1/2-5/8" tall. The one a lot of vendors are selling is over an inch tall and is ridiculous. Just went thru this on a friend's '67. Same problem. Thing was, this was supposedly the "correct" skinned seal, the most expensive one. He sent it back, got the cheap one, and the trunk fit was perfect. The new "correct" seals I've been seeing have no resemblance whatsover to the original seals. I got a new seal about 5 years ago for the '65, and it was identical to the original seal. I don't know what's going on these days with all these huge seals I'm seeing on ebay cars, etc. Get the right seal. Man, I sure said "seal" a lot!!!!
post #4 of 13 (permalink) Old 12-24-2010, 02:26 PM Thread Starter
Lip does point out and it is about 1/2 to 5/8" thick if you measure what is exposed. I actually ordered the part myself from Year One. Unfortunately I do not have the original to compare to.
BWGoat is offline
post #5 of 13 (permalink) Old 12-24-2010, 02:34 PM
I have HEARD, that SoftSeal brand trunk gasket is too thick and causes this problem.......I have also HEARD that Steele is a very good brand and is a little thinner so this problem doesn't occur.
Eric Animal is offline
post #6 of 13 (permalink) Old 12-24-2010, 02:48 PM Thread Starter
Thanks Eric and Merry Christmas!! Hope that '67 project is going well. Will I have a big problem removing the adhesive on the old seal without damaging the paint? Is there a release agent?
BWGoat is offline
post #7 of 13 (permalink) Old 12-24-2010, 06:55 PM
I don't know what it is glued down with...3M adhesive? Also what kind of Paint is on the car? I am sure there is a way to remove it, but you MUST know the answers to both questions. Ask the guy who installed it. Good luck! Go slow. Eric MERRY CHRISTMAS !
post #8 of 13 (permalink) Old 12-24-2010, 08:15 PM
Quoted: 117 Post(s)
Merry Xmas to all, as well. On mine, I used a little 3m weatherstrip adhesive, and used hardly any. The channel holds the strip in place. Mineral spirits, or MEK should do it.....I can't guarantee your paint holding up. I'd be inclined to pull it out and work on the cling-ons very very carefully. Or take it back to the restoration shop and ask them to install a correct seal that actually fits.....
post #9 of 13 (permalink) Old 12-25-2010, 08:05 AM
daveh70's Avatar
Merry Christmas.
Can't any adjustments be made to the trunk lid hinges to make the seal work?
This reminds me of the situation with the hood/cowl seal I got for the restoration on my '64 currently in progress. The seal in makes the hood pop out, but without it the panels are nicely flush. Adjustments COULD be made to make it flush with that cowl/hood seal in place, but I decided they just scrap that seal. It's not really needed anyway. Gotta remember these cars were built back then to drive every day, which doesn't happen anymore.
Dave
daveh70 is offline
post #10 of 13 (permalink) Old 12-25-2010, 10:05 AM
68greengoat's Avatar
Merry Christmas everyone..............
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
rear window rubber seal at bottom of windows kind of loose... pctek Exterior Discussions 0 07-18-2010 03:33 PM
68 Trunk seal Dgto68 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 06-17-2010 05:48 PM
Main Seal stude368 Engine Discussions 4 11-03-2008 01:58 PM
Trunk, Rubber Trim Mike_V Exterior Discussions 4 11-12-2006 05:42 AM
problems with trunk not closing? rippinbyu Service, Maintenance and Technical Discussion 4 12-26-2005 12:04 PM
