Trunk Rust - Best Way to Repair? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-15-2015, 05:43 PM Thread Starter
Hi,
I have been cleaning my 1967 GTO under carriage and treating with POR 15 and was greeted today with some new found rust! See attached picture, what is the best way to replace the rusted piece? I know Ames sells them, but how do I get the rusted one off? Do I need to cut the trunk floor to access?
Both the left and right side on the rear are rusted. I keep reminding myself that these cars were designed to last 7-10 years and not 50 ..../
Thanks,
Tony
TonysGoat is offline
post #2 of 2 (permalink) Old 11-15-2015, 08:36 PM
Tony,
If that is the trunk floor brace you will be able to drill the spot welds with a spot weld cutter. Then you can plug weld the new brace in place. More than likely the cage nut inside the brace will be rusted and you will have to cut the old brace to remove the body mounts.
05GTO is offline
Remove, Repair Rust,and Replace Vinyl Top smitka66 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 02-19-2012 06:33 PM
zero rust vs rust encapsulator tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-11-2011 06:07 PM
Rust repair suthin_man 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-21-2008 07:23 PM
Small rust in trunk of a 66 Lemans-Big Concern?? darkalley 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-18-2005 11:32 PM
