Trunk seal? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 04-23-2011, 06:35 PM Thread Starter
Trunk seal?
Does any one have any tips or tricks to keep the water out of the trunk area?
bigrc2 is offline
post #2 of 9 (permalink) Old 04-23-2011, 07:26 PM
crustysack's Avatar
replace the seal and use plenty of adhesive. also sand the side of the seal you are putting the glue on lightly with 100 grit sandpaper. this removes the mold release agent that is on the new seal
crustysack is offline
post #3 of 9 (permalink) Old 04-23-2011, 11:24 PM
400fitz's Avatar
Make sure that the water in your trunk is coming from you rear window. My 68 has only seen rain 3x in last 14 years and all moisture after the rain came from the rear window.Check your package tray to make sure it is nice and dry.i hope so!
400fitz is offline
post #4 of 9 (permalink) Old 04-24-2011, 12:31 AM Thread Starter
Ok thanks what type adhesive should i be useing on that? Agian Thanks for your help!
bigrc2 is offline
post #5 of 9 (permalink) Old 04-24-2011, 06:33 AM
There is a special adhesive for this from Ames or P.Y. You can pick up adhesive from say Auto Zone or NAPA too. Make sure your hinges are adjusted and functioning properly.
post #6 of 9 (permalink) Old 04-24-2011, 09:19 AM Thread Starter
Ok Thanks alot guys!!
bigrc2 is offline
post #7 of 9 (permalink) Old 04-30-2011, 11:16 PM
3m weather strip adhesive, yellow or black.
pontiac is offline
post #8 of 9 (permalink) Old 05-01-2011, 09:46 AM
66tempestGT's Avatar
also can leak around tail lights
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #9 of 9 (permalink) Old 05-04-2011, 06:34 AM
SIXT5GTO's Avatar
Tail lights
I will have to agree, one of the things often over looked is the tail light gaskets.
The wifes car had a problem with the truck acting as a water storage device.
To my suprise when working on the tail light, the gaskets where missing or in such bad shape the gaskets did little to keep water out
SIXT5GTO is offline
Trunk rubber seal problems BWGoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 12 12-28-2010 09:10 PM
68 Trunk seal Dgto68 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 06-17-2010 05:48 PM
65 hood/cowl seal injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-16-2010 09:56 AM
Main Seal stude368 Engine Discussions 4 11-03-2008 01:58 PM
Rear seal replace gman26 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-22-2006 12:30 AM
