trying to remove adhesive under vinyl roof - Pontiac GTO Forum
post #1 of 12 (permalink) Old 12-31-2011, 06:30 AM Thread Starter
Guys,
I've already taken the vinyl roof off the car, now I'm trying to
get the adhesive off. I've tried sanding it with a d.a., but it takes forever.
Any suggestions would be appreciated.
Thanks,
Paul
pbertrand65GTO is offline
post #2 of 12 (permalink) Old 12-31-2011, 06:48 AM
Chemicals? Citrus waterbased. Try some adhesive remover for flooring. Do small areas let it sit and soften then putty knife it off rinse then sand.
post #3 of 12 (permalink) Old 12-31-2011, 10:13 AM
Yep, it takes forever. Welcome to the club
Be careful about going crazy with chemicals --- remember that whatever you put on also has to come completely off, otherwise you could be in for a nasty surprise later when a miniscule drop of it that was hiding in some corner of a body seam bubbles up through your new paint job and ruins it....
BearGFR is online now
post #4 of 12 (permalink) Old 12-31-2011, 04:54 PM
crustysack's Avatar
aircraft stripper- available at auto zone, napa, pep boys etc- this takes everything off of anything- do not put it in the wrong place will remove paint,primer, everything but the metal
crustysack is offline
post #5 of 12 (permalink) Old 12-31-2011, 08:13 PM
69Goatee's Avatar
A local resto shop owner told me a trick to take it off, summer sunlight. The glue is sensitive to uv rays and heat. I took the vinyl top off, left the car in the summer sun for about a week. Then it crumbled off. I know this is the wrong time off year to do it, but I wonder if a uv lamp will do the job.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #6 of 12 (permalink) Old 01-01-2012, 12:24 AM
3M adhesive remover
pontiac is offline
post #7 of 12 (permalink) Old 01-01-2012, 09:25 AM
Have you tried a hair drier to soften it?
post #8 of 12 (permalink) Old 01-06-2012, 08:17 AM
68greengoat's Avatar
Originally Posted by pontiac View Post
3M adhesive remover
You beat me to it......
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #9 of 12 (permalink) Old 01-07-2012, 06:55 PM Thread Starter
Guys,
thanks for all the ideas. I am having luck with the d.a. I borrowed from a friend. It's pretty heavy duty, I have to be careful not to generate heat with it.
I will still try some of the above ideas. As good as the d.a. is, it still takes quite a bit of time. I guess there aren't any shortcuts.
post #10 of 12 (permalink) Old 01-07-2012, 07:03 PM
Wear a mask, don't breath that crap.
64 vinyl top lew64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-22-2011 10:40 PM
Vinyl Top removal MotoCrazy 1964-1974 Tempest, Lemans & GTO General Discussion 12 07-03-2011 01:23 PM
Vinyl top installation AMT1379 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-18-2010 10:42 AM
Dash vinyl blondie67 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 11 11-03-2008 12:08 PM
