Trying to repair my lower bucket seat frame - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-12-2014, 06:43 PM Thread Starter
par4n1's Avatar
has anyone had to repair the rusted out hog ring clips on their seat frame(s)? I have a few ideas but non proven. Here are two pics one of the damaged area and the other a possable fix using some old seat springs "weaved" through the seat. Please give me any advice
ID:	39138   Click image for larger version
par4n1 is offline
post #2 of 7 (permalink) Old 05-12-2014, 07:56 PM
Grab a mig welder and patch the areas up with fresh metal, clean and paint. Once the upholstery is on it's not like it's going to show anyway.
post #3 of 7 (permalink) Old 05-13-2014, 03:53 PM Thread Starter
par4n1's Avatar
They are attachment points and I have extremely limited access to a welder if any. I may just through bolt some eyelets it just scares me to have anything come loose once the covers are installed. Thanks for your responce
par4n1 is offline
post #4 of 7 (permalink) Old 05-14-2014, 04:56 PM
Quoted: 118 Post(s)
If you decide to use eyebolts, just use locktite and lock washers. Once in place, there is no way they'll come loose. Or, take it to a welding shop and have it done for maybe $20.
post #5 of 7 (permalink) Old 05-15-2014, 08:04 PM
tiger13's Avatar
Par4n1, where in Virginia are you located? I am in Northern NC, Henderson, right near the Va, line just off Rt 85 if you are close enough to drive to me, I will weld them up for you for free.
tiger13 is offline
post #6 of 7 (permalink) Old 05-22-2014, 06:22 PM Thread Starter
par4n1's Avatar
Thank you Tiger13. I found friend of a friend in Richmond and we (he) welded some strips cut from a 4x4 electrical box cover. The project took all of 10 minutes and worked perfectly. Thanks agin for your offer
par4n1 is offline
post #7 of 7 (permalink) Old 05-23-2014, 07:26 AM
tiger13's Avatar
Not a problem . I have been helped by people on here, and just want to pass it along. Glad to try to help, and glad your on your way!
tiger13 is offline
64 lemans lower A-piller repair t9370ml 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-28-2012 08:19 PM
lower fender repair Logchain 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 10-06-2012 08:36 PM
Lower Rear Valence Repair PatrickNJ 2004-2006 GTO General Discussion 6 04-21-2006 08:06 AM
