under coating residue - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-28-2012, 07:47 PM Thread Starter
I have been working on removing the old under coating from the bottom of my 66 Lemans. I used a torch and a wire wheel to remove the old coating. The old coating was beyond saving and in the process I found small rust holes in the floor pans and trunk pans that I welded up. The problem that I am having is the black film left on the metal from the under coating. I need to remove the film before I spray Zero Rust. What is the best way to remove this film. I tried a little sand blasting but it did not work very well.
tspring is offline
post #2 of 7 (permalink) Old 05-28-2012, 11:48 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Have you tried a chemical stripper? Maybe lacquer thinner? Whatever you do, do not use brake clean and weld afterwards, it produces a potnetially deadly off-gas unless THOROUGHLY cleaned.
chuckha62 is offline
post #3 of 7 (permalink) Old 05-29-2012, 08:41 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Second on the lacquer thinner I would get a big bag of terry towels at autozone and scrub away.
FlambeauHO is offline
post #4 of 7 (permalink) Old 05-29-2012, 09:42 AM
i was gonna say Brakekleen....didn't know about the off gassing.
Eric Animal is offline
post #5 of 7 (permalink) Old 05-29-2012, 11:18 AM
I've had good results with aerosol aircraft stripper which can be found at most auto parts stores. The brush-on stripper is not as good as the aerosol spray-on type.
05GTO is offline
post #6 of 7 (permalink) Old 05-29-2012, 12:00 PM
68greengoat's Avatar
This story was posted awhile back on this forum. Brake cleaner and heat do not work well together. Thought it would be a good time to bring it back up....
Brake Cleaner = Phosgene Article
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #7 of 7 (permalink) Old 05-29-2012, 03:06 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Thanks for posting that. I had read it a couple of years ago, but didn't know where I had found it.
Chuck
powder coating GOGTOGO 2004-2006 GTO General Discussion 1 05-30-2011 03:03 PM
Remove white residue left over from wax? GymChamp 2004-2006 GTO General Discussion 8 02-22-2010 08:38 AM
Powder coating Rukee Drive train, suspension, alignment and brakes. 3 05-21-2007 01:06 PM
