Valley pan mystery - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-04-2010, 05:28 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
Valley pan mystery
I know you guys told me I need a valley pan and I think I have the rusted old one.
How come I cant find it in the service manual for my 67 Goat? (400 HO)
Does it bolt to the bottom on the intake manifold?
Pretty sure the gasket goes on the block?
It dosn't seem to be in the restoration manual either.
thanks as always.
Topkat is offline
post #2 of 8 (permalink) Old 12-04-2010, 07:05 AM
jetstang's Avatar
It bolts below the intake on the block, not on the intake. Every Pontiac uses a valley pan.
Burning rubber since 1982!!
jetstang is offline
post #3 of 8 (permalink) Old 12-04-2010, 03:53 PM
Quoted: 117 Post(s)
Make sure it is CLEAN inside and out, and when you tighten it down with the 2 hold down bolts, use a little RTV under the washers. Do NOT overtighten those bolts. Just snug.
post #4 of 8 (permalink) Old 12-04-2010, 03:54 PM
Thor7352's Avatar
Valley Pan
The following picture (courtesy of High Performance Pontiac), shows an original Valley Pan (in hand) and a new one bolted on the engine. Note to two bolts located on the centerline of the pan that hold it down. There is a gasket between the Valley pan, heads and engine block.
Thor7352 is offline
post #5 of 8 (permalink) Old 12-05-2010, 05:02 AM Thread Starter
Topkat's Avatar
Thanks guys.
That one there must be a non pcv pan
the pcv one has a hole in it somewhere i believe
Topkat is offline
post #6 of 8 (permalink) Old 12-05-2010, 11:04 AM
Quoted: 117 Post(s)
Yeah, you can see the "hole" right at the tip of his right middle finger. That's the PCV grommet.
post #7 of 8 (permalink) Old 08-05-2014, 10:35 PM
Where can I find a gasket for the valley pan?
Berto504 is offline
post #8 of 8 (permalink) Old 08-11-2014, 11:03 AM
chuckha62's Avatar
Quoted: 18 Post(s)
I got one with the Intake Manifold Gasket Kit from Felpro.
chuckha62 is offline
Valley Pan Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-02-2010 08:06 AM
valley pan 68gtohawk8369 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-10-2010 02:56 PM
'66 Valley Pan color? MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-09-2010 09:33 PM
Valley pan in a 400ci dlloyd443 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-16-2008 01:53 PM
