Water pump for 69 - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-07-2019, 09:46 PM Thread Starter
Quoted: 17 Post(s)
Water pump for 69
I need a new water pump for my 69 Ram air 3 judge and I'm seeing a few different hub heights available. I don't have the original pump. Which is correct? Who makes a good quality replacement pump? Thanks
greenjudge69 is offline
post #2 of 8 (permalink) Old 03-07-2019, 09:55 PM
Quoted: 11 Post(s)
Early production 69's had a 4" hub height and mid year they changed to 4.5", what is the date stamp on the block?
05GTO is online now
post #3 of 8 (permalink) Old 03-08-2019, 04:09 PM Thread Starter
Quoted: 17 Post(s)
I don't have the original block in the car. The one I have is a 400 from November of 1968, ( k code). Thank you
post #4 of 8 (permalink) Old 03-08-2019, 06:45 PM Thread Starter
Quoted: 17 Post(s)
Oops. Just realized my timing cover is the 69 and newer with 11 bolt holes
post #5 of 8 (permalink) Old 03-10-2019, 07:37 PM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
ooops ? sounds like you should have said YAH !
so you still need a 4.5" 69 dated rebuilt water pump ??
contact Ol pinion here on the forum
he should help you right out
whats your water pump pulley number ?
better yet
what crank and power steering pulley numbers you running?
BLK69JUDGE is online now
post #6 of 8 (permalink) Old 03-11-2019, 12:06 PM
dan woodland's Avatar
Quoted: 34 Post(s)
Make sure you source the proper pump that matches the pulleys in your car. When Pontiac switched pumps as mentioned above they also switched pulleys to match the new shaft length. Or if you switch to the opposite pump you can match the pulleys to that... Until recently you could not get the 4" pump, you would have to find and old one and have it rebuilt. I know as I tried for over two years but recently Ames Performance started to carry them.
*67K miles... Under Construction* :)
dan woodland is offline
post #7 of 8 (permalink) Old 03-11-2019, 09:58 PM Thread Starter
Quoted: 17 Post(s)
I'll check the pulleys tomorrow.
post #8 of 8 (permalink) Old 03-12-2019, 03:12 PM Thread Starter
Quoted: 17 Post(s)
The crank pulley is a, 481037 YA. And the water pump pulley is a,. 9788886-XT. I'm guessing both are incorrect for my application. 69 RA 3 judge with power steering,. No AC. What would the correct numbers be for this application? Thanks
1966 Original Fuel Pump and Water Pump Part numbers redandwhite66 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 07-19-2018 05:18 PM
69 GTO Water Pump Okies69 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 07-12-2018 01:51 PM
69 GTO 400 block Short or long water pump jtwoods4 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-09-2012 03:20 PM
'69 water pump Q etewald 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-15-2012 01:56 PM
