what are they for #14 and 2 other ?'s - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-01-2010, 06:48 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
First, what are these bolts for?(note the striations)
Is the 2nd pic a windage tray?
What are the chances of getting it dipped and re-using it?
3) I grew up with the idea that replacing an oil pump was cheap insurance during a rebuild. But this pump seems (partly based on the parts diagram) REALLY heavy duty. is re using it a good idea?
thank thanks and more thanks!
ID:	9170   Click image for larger version
ID:	9171   Click image for larger version
Topkat is offline
post #2 of 6 (permalink) Old 11-01-2010, 06:55 PM
Quoted: 118 Post(s)
!) starter bolts. 2) valley pan, not a windage tray. It needs to be really clean inside and out otherwise you'll get crud and grit sucked into your engine. Get it really clean or get another one that isn't all rusted. Don't get the wrong, later valley pan with the PCV at the front. Maybe a dip in diluted muratic acid? 3) get a NEW oil pump, and make sure the pickup tube is pressed in tight.
post #3 of 6 (permalink) Old 11-01-2010, 07:12 PM Thread Starter
Topkat's Avatar
Does the valley pan go between the lifter valley and the intake manifold?
Topkat is offline
post #4 of 6 (permalink) Old 11-02-2010, 08:04 AM
jetstang's Avatar
Yes.
You can open the oil pump up and look for wear on the top plate. It may have a little tab that tells what it is, look for a HV on it, High volume. I would get a new pump myself.
Burning rubber since 1982!!
jetstang is offline
post #5 of 6 (permalink) Old 11-02-2010, 08:07 AM
Yes, get a new pump and pick up screen, then weld the tube from the screen to the pump. It only needs a small weld, not all the way around. Then while upside down, poor oil in the screen and turn the oil pump shaft untill it starts to pump the oil before you bolt it on the block.
post #6 of 6 (permalink) Old 11-02-2010, 09:43 AM
67 Basket Case Restorer
Too Many Projects's Avatar
When you go to buy a gasket for the valley pan don't call it that. The parts people won't find it on their computer. To them it's a "push rod cover"...
If you have an engine/transmission rebuilder nearby, take it to them to have it cleaned in their hot tank.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
