Where to find Hurst dual gate? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 06-14-2009, 12:10 AM Thread Starter
Where could I find a dual gate shifter kit to put in a 69? How difficult to do as such? what is a reasonable price for the complete unit?
clarkaim is offline
post #2 of 16 (permalink) Old 06-14-2009, 09:24 AM
a really good his/hers shifter will cost about 250 on e-bay. you will need to gey one for a 1968 GTO....NOT A 67. If you can find one already in a 68 console, it should fit in your 69. This was NOT an available option in 69, but can be adapted to fit.......eric
Eric Animal is offline
post #3 of 16 (permalink) Old 06-14-2009, 06:06 PM Thread Starter
How hard will it be to do this? I mean, other than things like trim, blinkers, vent windows, rear bumbers, 68's and 69's are pretty much the same right? I've never installed one of tehse, how hard to do? I just think they are cooler than the regular shifter in the 69
clarkaim is offline
post #4 of 16 (permalink) Old 06-15-2009, 07:43 AM
The floor should be the same. you should be able to switch the consoles, then hook up the shift cable. I am not sure about the neutral safety switch, and such......E
post #5 of 16 (permalink) Old 06-16-2009, 02:00 PM
67/04gto's Avatar
the cables where different i thought
67/04gto is offline
post #6 of 16 (permalink) Old 06-17-2009, 10:26 PM
Yes, but readily available.
post #7 of 16 (permalink) Old 11-22-2010, 12:39 PM
I know this is a very old thread, but you do know that your factory 69 shifter also has a manual/ratchet mode of operation, right?
Pull it down into low, then when upshifting push it out/away from you at the same time that you're pushing it forward (like at a 45-degree angle away from your body - towards the glove compartment). It will up-shift into 2 and lock. After the up-shift, let the pressure off the shifter just a little and it will reset, ready for the 2-3 upshift. If you'll look really closely at the woodgrain on your console next to the shifter on the passenger side of the opening, you'll see 1 2 3 embossed there. That's what it's for.
post #8 of 16 (permalink) Old 11-22-2010, 01:03 PM
It does it on a '70 too. Pretty cool.
post #9 of 16 (permalink) Old 11-22-2010, 03:07 PM
Very TRUE, and would be "year correct" !
post #10 of 16 (permalink) Old 11-26-2010, 07:53 PM
hi i think i have an extra dual gate shifter in the garage
revup47 is offline
GTO Hurst Dual Gate Shifter Question SlowAces 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-12-2013 03:38 PM
More Hurst Issues Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-06-2009 04:06 AM
Hurst Shift Knob 06' kicks06 Drive train, suspension, alignment and brakes. 4 04-08-2008 09:23 AM
Hurst Rims jeffdetrick 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-15-2007 09:36 PM
Hurst Dual Gate for 70 Ragtop70 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-18-2006 11:08 AM
