Window Issue - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-06-2017, 10:20 AM Thread Starter
Quoted: 5 Post(s)
Window Issue
Hi everyone,
I'm new to the forums but have a question about windows. I have a 1967 GTO and recently noticed the passenger side window was not going up all the way. It seemed to fall short about a half an inch. In an effort to help it along that last bit I gently pulled up on the window while cranking it up. When it hit the stop, the window pulled right out. I took the door panel off and noticed a "track" where the window sat and got the window back in place. In searching I now know the glue failed in that track. I see regulators for sale, but not with the track and I can't find the track by itself. The window kind of works now but is loose in the track and does not go all the way down. It gets hard at about 3 inches from the door. The regulator looks ok and it may be a matter of adjustment, but I'm not sure. The track itself looks a little rusty but I think I can clean it up.
Is this track replaceable? I didn't get a good look at it before I buttoned it back up.
Should I just scrape out the old adhesive as best I can and glue the window back in place with epoxy (as instructed by a body guy) or should I look to replace everything if I can find it? Any other tips?
Thanks in advance.
supergrizzly is offline
post #2 of 4 (permalink) Old 09-06-2017, 12:57 PM
I would keep your original track. Just clean up the inside and buy the correct adhesive window tape to re-install your glass. Once you get that taken care of you can mess with all the adjustments to get the window sitting correctly.
1964SS is offline
post #3 of 4 (permalink) Old 09-07-2017, 07:57 AM Thread Starter
Quoted: 5 Post(s)
Thanks for the response 1964SS,
You mention tape for the install. The only tape I have seen is noted for windshields. Would it be the same tape? It would be much easier and cleaner to use tape as opposed to the two part epoxy suggested by an older body and paint guy I know. If not the same tape, any suggestions on where to find?
Thanks again.
post #4 of 4 (permalink) Old 09-07-2017, 02:16 PM
A local auto glass shop around you should have it available. If you can't find it locally there are places you can get it online. It's called glass setting tape and you just have to get the right thickness for your channel. Here are a couple links for reference.
1/16" Auto/Truck Glass Setting Tape for Early Channel Type Frames 20 Foot Roll
Rubber Glass-Setting SealStrip #646 - 1/16" Thick X 1-1/4" Wide - J & J Auto Fabrics, Inc.
1964SS is offline
Window help please! Pat68HO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 01-02-2014 12:14 PM
another window issue BAD2006 2004-2006 GTO General Discussion 4 10-26-2013 10:10 AM
Still having the same issue..... xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-17-2013 10:24 PM
Common Window Issue? doubleb0924 Service, Maintenance and Technical Discussion 10 11-30-2011 02:52 PM
