Zebart removal - Pontiac GTO Forum
post #1 of 24 (permalink) Old 12-22-2011, 09:19 PM Thread Starter
bowsher21's Avatar
Zebart removal
I searched for Zebart removal but didn't find anything on this site so, I thought I would ask the question; How should I remove the Zebart and other undercoating from the underside of my project?
I guess I was lucky the car was Zebarted, nearly no rust but this is gonna take some time to clean up.
Name:	chucks gto 018.jpg
bowsher21 is offline
post #2 of 24 (permalink) Old 12-22-2011, 10:33 PM
Quoted: 23 Post(s)
coarse sand will bounce right off it...i know (7 bags worth). i left mine and re-hit light areas... I would think some type of solvent or paint stripper would dissolve it but thats nasty and messy. Do not know if soda blasting will touch it. I figured it does the job it was designed for and has preserved the undercarriage for 45 years why fight it, to me it was'nt worth all the work to strip and paint but i did not take the body off the frame either. It also protects from chips and scratches as well as moisture, once the painted frame/underbody gets scratched from stones if you drive it, it will start to rust.
Instg8ter is offline
post #3 of 24 (permalink) Old 12-22-2011, 10:55 PM Thread Starter
bowsher21's Avatar
Blasting of any sort is a waste of time and materials. All it does is move the goo around. Even steam cleaning takes way too long and still leaves a film. I know diesel will melt it but it stinks and is real messy.
I would leave it if not for the incomplete application around the rear end. That area around the fuel tank and hard to shoot over the spring buckets has a surface rust so, I will be painting the complete underside.
post #4 of 24 (permalink) Old 12-22-2011, 10:56 PM
Quoted: 23 Post(s)
dry ice and chip it off give the citrustrip a shot its non toxic and smells like oranges.
post #5 of 24 (permalink) Old 12-22-2011, 11:16 PM Thread Starter
bowsher21's Avatar
Citrustrip, now that is a good idea! Got to start to clear the "old car smell" out anyway.
I wonder if they put it in a steam cleaner form? Not big on dry ice but I could leave the car outside for a few days during in the below 0 deg weather and try the chipping air hammer attachment.
post #6 of 24 (permalink) Old 12-22-2011, 11:40 PM
Quoted: 23 Post(s)
dry ice is -80 F i dont think that setting it outside will do it as the worst weather we have is well within the products temperature range. citrus strip brushed on heavy and let set until you see lifting then scrape. I think I have seen dry ice blasters on youtube.
yep
post #7 of 24 (permalink) Old 12-23-2011, 12:06 AM
acid dip body, only way for sure.
pontiac is offline
post #8 of 24 (permalink) Old 12-23-2011, 07:42 AM Thread Starter
bowsher21's Avatar
I do plan on dipping the front clip but not the body. I am told the acid/ striping fluid is very hard to be sure it is out of seams and can come back years later lifting the paint.
post #9 of 24 (permalink) Old 12-23-2011, 09:10 AM
Quoted: 102 Post(s)
My '67 GTO convertible is a Baltimore built car, was registered in Tennessee, and came to California in 1983, when I bought it. The ONLY reason it still has its original floorpans in good condition is because it was Ziebarted when new. The stuff is tough as nails, is a heat and sound deadener, and has preserved my floorpans for going on 45 years now. I have no plans to remove it any time soon........it's part of the car's history.
post #10 of 24 (permalink) Old 12-23-2011, 09:44 AM Thread Starter
bowsher21's Avatar
Talk about solid floor pans and rockers, check this out. The Zebart did it's job but the car won't be driven in the winters again or any time soon so off it go's.
I just couldn't do a nice job on the rest of the car and have the bottom look nasty. I'll do my best so not to over restore it.
ID:	13331   Click image for larger version
68 dash removal xcmac26 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 11 12-28-2013 02:11 PM
66' lighter removal Instg8ter 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-19-2010 01:06 PM
Lug Nut Cap Removal Tool? CycloneGTO Wheels and tires 5 11-21-2006 12:51 PM
Tar Removal ALTEREGO The Lounge 4 08-25-2005 08:52 PM
