zero rust vs rust encapsulator - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-11-2011, 04:22 PM Thread Starter
I was thinking about sand blasting my 66 LeMans body and then spraying the entire body with zero rust or rust encapsulator from top to bottom. This way I can work on the dinks and dents with body fillers without worrying about flash rusting.Does this sound like a good plan. Also what are yalls opinion of zero rust compared to rust encapsulator. zero rust is about half the price of rust encapsulator. I know you can apply rust encapsulator over body filler and apply body filler over rust encapsulator but uncertain about zero rust.
tspring is offline
post #2 of 4 (permalink) Old 09-11-2011, 05:16 PM
Quoted: 23 Post(s)
I applied a coat of epoxy primer to do the body work over it will accomplish the same thing (seal out moisture) and be cheaper and a tougher finish for sanding into.
http://s1098.photobucket.com/albums/...966%20Tempest/
Brian
Instg8ter is offline
post #3 of 4 (permalink) Old 09-11-2011, 05:26 PM Thread Starter
My problem is that the body has surface rust in spots The rust is not bad enough to cut out but will require some filler to smooth out.
tspring is offline
post #4 of 4 (permalink) Old 09-11-2011, 06:07 PM
Quoted: 23 Post(s)
you can spot hit those with either product, i used rust reformer on spots just hit it with a wire wheel and then encapsulate the area that has rust (those products convert rust) you dont need them on good bare metal. Then hit the whole car in epoxy as a base for the body work to grip too and it will seal out any moisture and dry hard as ceramic. if you kiss through it to metal have rattle can of GOOD "etching primer" handy and spot prime the metal to avoid rust....
65 GTO with a little bit of rust. Thumpin455 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 318 01-10-2014 09:29 PM
What to do with this rust? BatmanGTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 26 08-16-2011 08:09 AM
frame rust denf221 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 02-21-2010 06:45 PM
rust out, help! danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-27-2009 08:11 AM
Some Rust GTO_KID 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 05-14-2008 07:26 AM
