1964 Pontiac LeMans Glove Box Hinge spring - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-03-2019, 02:55 PM Thread Starter
Hello,
Anyone know of a source for glove box door hinge springs?
Okay, so the glove box door is basically a poor design in my opinion, you push the button to open the glove box which pushes the door closed. How the tiny torsion spring on located on the hinge is supposed to over come me pushing the dang button does not make sense. Anyway. I know it must of worked somewhat better in the past, now it just mostly stays locked unless I use something to pry open the door while I push the button.
You can see the spring in the attached picture.
Thanks for your consideration and or assistance.
Cheers,
Bob
advchaser is offline
post #2 of 3 (permalink) Old 02-03-2019, 08:29 PM
Quoted: 365 Post(s)
Originally Posted by advchaser View Post
Hello,
Cheers,
Bob
I would email Franks - https://www.frankspontiacparts.com/
post #3 of 3 (permalink) Old 02-04-2019, 07:44 AM
Quoted: 134 Post(s)
Are you sure the striker mechanism is adjusted properly? The spring does not appear to be broken.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
  Pontiac GTO Forum > Buy / Sell / Wanted (1964-1974) > 1964-1974 GTO's and Parts Wanted
67 hood hinge spring???? billcocarb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-19-2011 04:53 PM
hood hinge spring Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 12-20-2010 02:00 PM
Glove Box Disassembly gtoik Service, Maintenance and Technical Discussion 5 07-21-2005 11:54 PM
