Pontiac GTO Forum
Pontiac GTO Forum (https://www.gtoforum.com/forum-index.php)
-   1964-1974 Tempest, Lemans & GTO General Discussion (https://www.gtoforum.com/f12/)
-   -   Dual Snorkel Air Cleaner Identification (https://www.gtoforum.com/f12/dual-snorkel-air-cleaner-identification-24068/)
chevelleman 11-05-2009 09:42 AM
1 Attachment(s)
I am trying to figure out exactly what year and model vehicle this air cleaner came off of? Any help would be greatly appreciated. I think it is late 60's early 70' GTO???
Attachment 5846
646904GTO 11-05-2009 10:31 AM
Looks like the one on my 1969 GTO. Very rare to find one these days since most were replaced with a full open aftermarket ones. Hang on to that gem!
68_Goat 11-06-2009 05:01 PM
Its likely 69-72 GTO....I have a green stenciled date on the inside of mine....from what I understand, there are some subtle physical differences, but I'm not sure what they are. 68 only had one snorkel.
Too Many Projects 11-06-2009 07:08 PM
Since he's a Chevelleman, it's most likely on ebay by now...:D
donb 07-13-2018 02:07 PM
what is the correct air cleaner for 68 GTO 400-4?? "HO"
BLK69JUDGE 07-13-2018 03:23 PM
and
2 Attachment(s)
PontiacJim 07-13-2018 09:00 PM
Dual snorkel, chrome lid.
donb 07-14-2018 04:11 PM
thanks Pontiac Jim
That's is what I thought - and then was recently told the dual snorkel chrome lid did not appear until the 69 model year.
I found a new / old on-line last week for $290 so I bought it to get away from the after market open chrome lid someone before me replaced it with. trying to get as original as I can.
see you are in Gastonia - I was in Statesville before moving to Austin, Tx about 22 years ago.
thanks for your help
DonB
Shake-N-Bake 07-14-2018 04:39 PM
According to my catalogs....single snorkel for 68 and dual for 69. Never seen an original 68 with dual snorkel air cleaner...
Sent from my SM-G930V using Tapatalk
PontiacJim 07-14-2018 05:54 PM
2 Attachment(s)
YOU are correct. My bad. I recall a forum discussion on this and simply could not find it to reflect back on. However, I did finally find it: https://www.gtoforum.com/f178/68-400-ho-details-125401/
I had quickly referenced the Pontiac GTO Restoration Guide and read the text which did not clarify. Did not find a photo which I thought it had - but I just found it going through the book again. Single snorkel, chrome lid, painted 60% gloss.
The HO used the same air cleaner as any GTO, single snorkel with chrome lid. 1969 and up had the dual snorkel and Pinion head provided a very detailed description of the different types. The only fly in the ointment was the supposedly original 1968 GTO HO 400 written of in Hemmings which had a dual snorkel. It was never determined if the owner installed this himself along the way OR it may have been a very late 1968 build that got the 1969 dual snorkel air cleaner - 'cause Pontiac did things like this.
So check out the thread and this should clarify. Personally, dual snorkel would be on my engine if I were to run something other than an open element air cleaner which I prefer and run. Something about the visual balance of two snouts versus just the one. :thumbsup:
A very interesting test was done by Engine Masters on air cleaner flow. One test included a dual snorkel air cleaner on a 750 HP engine. The dual snorkel showed a loss of 53 HP. When flipping the lid over, it lost only 11.9 HP. The best was an open velocity stack which increased HP by 5.7 HP and the fly in the ointment that came in as second best was a fitted salad bowl which increased HP by 3HP.
Keep in mind this 750 HP engine was no doubt a big breather and it spun some higher RPM's. I don't think you would see the same kind of losses on a lower RPM/HP type engine.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
