1 - 17 of 17 Posts
And here is the summary for the 04...
Make : PONTIAC Model : GTO Year : 2004
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 03012005 Date of Bulletin: MAR 01, 2005
NHTSA Item Number: 10014871
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary:
NO AUDIO CONDITION FROM THE RADIO. *EH
Check to Request Research. Submit below.
Service Bulletin Num : 050849003 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10013486
Component: ENGINE AND ENGINE COOLING
Summary:
SPEEDOMETER ERRATIC MOVEMENT FUEL GAUGE DOES NOT GO TO FULL AFTER FILLING ENGINE COOLANT TEMPERATURE GAUGE READS HOT AND COOLANT TEMPERATURE LIGHT ILLUMINATES. *EH
Service Bulletin Num : 040310013 Date of Bulletin: OCT 01, 2004
NHTSA Item Number: 10011058
Component: SUSPENSION
Summary:
DRIVING CHARACTERISTICS OF REAR-WHEEL DRIVE AND AVAILABLE WINTER TIRES. ALSO INCLUDES THE 2004-2005 CADILLAC CTS-V. *TT
Service Bulletin Num : 09072004 Date of Bulletin: SEP 07, 2004
NHTSA Item Number: 10013191
Component: STRUCTURE:BODY
Summary:
PAINT PEELING FROM THE FRONT OR REAR FASCIAS. *EH
Service Bulletin Num : 040603006 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011040
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
PROPER JUMP STARTING PROCEDURE. *TT
Service Bulletin Num : 040522001 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011053
Component: SERVICE BRAKES, HYDRAULIC
Summary:
WHISTLE NOISE WHILE VEHICLE IS STATIONARY WITH BRAKES APPLIED. *TT
Service Bulletin Num : 040849023 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011076
Component: ELECTRICAL SYSTEM
Summary:
SPEEDOMETER MPH INDICATOR TOO HIGH BRIGHT. *TT
Service Bulletin Num : 040868003 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10011088
Component: VEHICLE SPEED CONTROL:CRUISE CONTROL
Summary:
KNOCK OR THUD NOISE WHEN CRUISE CONTROL IS ON OR OFF. *TT
Service Bulletin Num : 040730025 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10008495
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
TRANSMISSION FLUID LEAK, INOPERATIVE 2ND/3RD/4TH GEARS, NO MOVEMENT, CASE CRACKED OR BROKEN AT 2-4 SERVO. GM LIGHT DUTY TRUCKS 2004. *MJ *TT
Service Bulletin Num : 040139011 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011193
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
DIAGNOSTIC INFORMATION FOR A/C REFRIGERANT LEAK AT CONDENSER CONNECTION. *TT
Service Bulletin Num : 040308014 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011196
Summary:
KNOCK NOISE FROM FRONT SUSPENSION WHEN DRIVING AT LOW SPEEDS OVER BUMPS/UNEVEN ROAD SURFACES. *TT
Service Bulletin Num : 040310010 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011199
Summary:
REFINISHING GTO SILVER PAINTED WHEELS. *TT
Service Bulletin Num : 040731004 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011218
Summary:
CLUTCH ACTUATOR CYLINDER BLEEDER SCREW ALIGNMENT. *TT
Service Bulletin Num : 040731005 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011219
Summary:
CLUTCH PRESSURE PLATE WEAR INDICATOR ADJUSTMENT. *TT
Service Bulletin Num : 040864018 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10011241
Component: LATCHES/LOCKS/LINKAGES
Summary:
FRONT DOOR LOCK WILL NOT UNLOCK OR WILL LOCK INTERMITTENTLY. *EH
Hey man thanks.
smkdu said:
Is that what I have to look foward to :confused
ALL new cars have issues, some more than others. It's nice with the internet that we have access to the TSB's. Even the high end BMW's and the like have new car issues, so don't fret, the GTO is a high quality performance machine.
Don't confuse a TSB is with a recall. It's simply a procedure to fix a problem. Unlike a recall, the only time GM was 'responsible' for them (TSBs) would have been when the car was under warranty.
1 - 17 of 17 Posts
