I have just last monday purchased a 05 yellow jacket m6.I bought it in mckenny TX.It was used a BOB TOMES ford.When I drove it home it did fine.Now every time I am sitting still idleing it will start heating up.Or at least it says it is.Then I found out some of the 05's had gauge cluster problem.To my understanding alot of the 04's had this problem.This morning I went out and cranked it and left it running while I was wipeing it down.Then all of a sudden It starts overheating,antifreze leaking out.Then it cooled down.So today after letting it sit for several hours.If you crank it and let it idle,heat gauge will come up then it will cool down when the thermestat opens.I know the thermestat is opening now because I had the heater on.But anyway It will never act up going down the road just siting and idleing.Heat gauge will come up and show hot and peg out on the gauge.Then if you rev it up it will go back down.The fans come on and all.The longer you let it idle the more it will do this ever now and then.I am suppose to take back to pontiac tues.Any body have any suggestions.I need all of your knowledge.HELP:confused
