Trying to put an air intake in the area or something? You need to have some sort of tank but there are aftermarket ones and they can be relocated.
re
eventually yes, the car will loose coolant. Thats what the over flow tank is for it captures what get forced out under pressure and then gets sucked back in as the car cools down. If you take the tank off, you will have to plug the over flow hose and I dont know how much pressure your cooling system will be under and how much it can take...danfigg
re
I should of just said "NO"...You cant remove the tank---danfigg
Sure you can remove it. I replaced mine with a "catch can" that is attached to the PS shock tower. Line goes from radiator overflow to the bottom of the catch can. Then hose from top of "catch can" run out of engine bay. Acts just like factory but adds a route to release excess coolant if needed.
