Is anyone running a 400 with #16 heads, on PUMP gas ?? If so what combo do you need to run?? (lotta talk that they create too much comp.)
Thanks, Duck..
It can be done on a 400, much harder on a 455. 16's have a nominal chamber size of 72 cc's, so to get the needed clearance volume the "best" solution is usually to run dished pistons.
If you are rebuilding your engine, Bear is correct. Usually you get the correct pistons with more cc's, aka dished pistons, or you can talk with a cam manufacturer who can "bleed off" some of the compression -type in "static compression verses dynamic compression" into your search engine and get ready for a lesson in compression ratio's. Another trick I have not seen in a long time used to be to add a water/alcohol injection system that was supposed to cool the intake charge on higher compression engines as well as give a little more power. Ever notice how your car runs stronger on a good cool damp night? I have seen a how-to article where the windshield washer pump/container was used and misted into the top of the carb via the air cleaner lid. I have seen kits for sale as well. It kicks in during wide open throttle. Might look into that as an option. I am considering one myself just as a precaution should I ever need it -even though I will have a reasonable compression ratio to run pump gas.
I run pump gas ( premium/ 10 percent ethanol) in mine but don't know if engine was ever rebuilt before I got it 20 some years ago. I drive like an old lady anyway.
Try using Ethanol Treatment. I use Sunoco 93 oct it has 10% corn/water. :(. I use Lucas's Ethanol Treatment 1 oz per 5 gallons. I noticed a difference in detonation. Their treatment can be used on E-85 it states, but there is no way in hell that garbage is going in any of my vehicles.
Also, consider this: In my 461, the difference between 9.2:1 compression and 10.0: compression, with no other changes made, is only worth a whopping 8 hp. (in an engine that's already over 500 hp). That makes pushing the envelope on compression to the razor's edge just not worth it.
