I recently acquired what I have determined to be a 1964 389 GTO motor. The engine code indicates it to have been from an Automatic tranny, and a 4 barrel carb.
Engine codes as follows: 79J 408363
Heads - Only numbers I can find are located on tags that are attached each by two pan head machine screws with the number "76" stamped into them. One each sits on the rear driver's side exhaust port, and the other sits on the front passenger exhaust port.
Anyone have any idea which heads these are. They don't have the stampings I've seen on others '64 389's.
Block & heads are painted what looks to be the original silver/blue metallic.
Thanks in advance for any help you guys can give!! :cheers
