1 - 15 of 15 Posts
I'm saving a 66 from a life ending in a scrap heap. I went on the hunt for a GTO or Lemans, and came across a 66 lemans in Oceanside, CA. I knew I would be in for quite a few hidden surprises, and I was right. When I found this thing, it had a 3 inch body lift and 24 inch wheels. I think that style, which I think is ridiculous, is called "Donk". My first thought was, "I need to rescue this car". He wanted 5000. And I talked him down to 2000. I took it home, pulled off the wheels and sold them the next day for 500, so the car cost me 1500.
http://4.bp.************/-zMXhMcbOpJk/Tbw6iHfOZlI/AAAAAAAAAaA/4ClMFV38KX0/s1600/2011-04-14_13-55-55_743.jpg
http://4.bp.************/-wKp1T9ofzwI/Tbw67ixfdfI/AAAAAAAAAaE/5Myf1udYLms/s1600/2011-04-14_21-23-40_30.jpg
I found a set of Rally ll's for it and ditched the lift kit.
I started pulling paint off the car so I could see just how bad it was under there. There is so much body filler on this thing, it's probably doubling the weight of the body. The roof was so badly rusted through, that I had to find a replacement, because there was no way it could be patched. I found a 66 out in the desert completely shot body and frame, but surprisingly the roof wass rust free. I handed the owner $100, pulled out my sawzall and got to work with the help of my brother.
http://4.bp.************/-Z0zs5NI-nR8/Tlz6wBthKyI/AAAAAAAADV8/3LNg_f5zZwQ/s1600/1366.jpg
http://3.bp.************/-kiHtFxkbJMg/Tlz6wKms2vI/AAAAAAAADWE/HvwocKYbXkM/s1600/1367.jpg
http://2.bp.************/-dzUSVA6v29Y/Tlz6wT_yJFI/AAAAAAAADWM/HyTbuHtZUHs/s1600/1369.jpg
http://1.bp.************/-_C3kCZ593GE/Tlz6wi-YR-I/AAAAAAAADWU/nMZYxfjwhII/s1600/1370.jpg
http://2.bp.************/-hfKqjpVz2n4/Tlz6wh9lZhI/AAAAAAAADWc/42rkNsG2RwI/s1600/1372.jpg
http://1.bp.************/-4q1kHREZBDM/Tlz615Q_9BI/AAAAAAAADWk/JhKa0hr047w/s1600/1373.jpg
Now I need to tackle the fenders. I also need to find an interior and a paint shop in the valley.
Thanks. Those cars in the background are customer cars at my buddies shop. This project is all I can handle right now, it's a beast.
I got the front off, and I was really happy to find very little rust.
Surprisingly this was the only rust hiding under the body panels.
Ha! Those shots would kinda hurt going down.
This was "Fix yer fenders" weekend. I found a couple 66 fenders sort of locally, and they were both in pretty poor shape, except for the bottom wheel well corners, which was all I needed anyhow.
Discussion Starter #13
Well, it runs and drives fine. Breaks are good, all the electrics work. I drove it back from ventura to LA with no issues. The seats and belts are all installed, as well as the dash a gto steering wheel, and new turn signal components in the column.
you know, you've done a solid chunk of the work on this thing so far... too bad to give it up, but it'll be a nice car for someone sooner or later! Big props to you, dude!
Discussion Starter #15
Yeah, it's kind of a bummer to give up the car now, but someone else will get it looking pretty in no time.
1 - 15 of 15 Posts
