Here is a pic of the Chevelle Hazzard assembly. It has 3 1/2 circle connectors vs two on the Pontiac version. Not sure it will work. Any thoughts?Ron, they are all the same. The Chevelle version will work in your '66.
Thanks for the photos!!!!Ron,
Not much to the Hazzard Switch install.
Unhook the battery.
Mount the switch onto the Parking Brake arm.
Plug the Bulb Socket into the provision in the lower speedo housing.
Plug the power lead to the PARK BRAKE acc terminal on the lower right of the fuse block.
Reconnect Battery.
Here are some pic of the Switch & Bracket I hope they are of help.
Thanks for the advice on the shoulder. I'm doing exactly what they are asking!! Long process..No. It's stand-alone, as seen pictured. Didn't go into the column until 1967. I used to see many of these units in junked GM cars in the '80's. Along with rear defoggers, visor mirrors, you name it. Those days are long gone. Ron, do ALL the rehab on that shoulder religiously. I had mine done in 2016 and made a 100% recovery. And am still doing rubber band/mobility exercises 3 times a week (by choice to keep in shape). It's a real SOB because the shoulder is so complex, but don't overdo anything and no lifting stuff after you 'think' it's healed....that's a great way to 're-injure' it. Take your time and do the PT. Good luck.
Buick, Olds, PontiacKnow to show my real ignorance: B.O.P, I'm assuming the P stands for Pontiac. What does the B and the O stand for?
I found this for a 66 Olds. Flare Stat 105. What do you think?Not even close, You would be far better with something from the 1966 B.O.P. family.
